Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
I have lens error problem. the lens are not going in completely
  • 148 Answers
The lens will need repairing!
Posted on Apr 02, 2009
My Lens will only close half way.
Hi Natalie:
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 15, 2011 | Samsung Digimax S800 Digital Camera
Sanyo digital camera showing lens error 1114 or 112
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
When we turn on our Sanyo VPC E1090 digital camera the lens does not appear to come out completely & we get an "lens error 0x0311" message on the screen then it turns off. WHAT IS WRONG!! ...
If lens does not appear to come out completely and camera gives error that means lens mechanism got broken internally and lens assembly will be replaced to solve the issue.
Lens replacement is not user level repair and local camera repair shop[ will do this job for you if camera is out of warranty.
May 28, 2011 | Sanyo VPCE1090 Digital Camera
Lens error
I've got the answers...
Problem: Lens error.
Symptom: Lens will not extend upon power up.
Cause: Lens is impeded while trying to extend.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the main drive gears to be damaged.
Solution: Replace the main drive gear assembly. This should only be done by a qualified tech.
If you've experienced this you know exactly what I mean. This should clear up any notion that the "Lens Gods" have cursed you. Although this may have appeared to be a mystery, it's always caused by something!
Symptom: Lens extends, makes a few buzzing noises and retracts, resulting in "lens error" message.
Cause: This is caused by damage to the focus lens often by impact, or sand in the mechanism.
Solution:The focus lens gears either need to be replaced or the assembly completely rebuilt. Again, this should be done by a qualified tech. It's a very delicate process.
Problem: Aperture unit failure
Symptom: images appear to be washed out, over exposed and often have horizontal lines through them.
Cause:The aperture unit is either stuck, damaged or not receiving the proper electrical signal to activate. The result is that the aperture remains open after the picture is taken and CCD is over exposed.
Solution:Completely rebuild the aperture unit, which requires complete lens dis-assembly and rebuild. Again, this should be done by a qualified tech. It's a VERY delicate process.
Additional details in THIS LINK.
Hope this helps.
Apr 27, 2011 | Casio Exilim EXZ75 Digital Camera
When I turn off my CoolPix S6 the lens would close completely. When I turn on my camera the lens is completely open and the screen just says lens cover error.
The lens is damaged and needs to be replaced. Sometimes with use or maybe an accidental hit to the lens can cause a malfunction to the camera resulting in that error. Also if you for example took the camera to the beach, getting something like sand in the camera can jam up the lens and prevent it from fully extending or retracting.
Mar 24, 2011 | Nikon COOLPIX S6 Digital Camera
Lens Error. I didn't do anything to my Canon Powershot A1100 and now I have a lens error that will not go away. My lens is completely zoomed in and won't move. Help!
Sometimes the lens is just stuck, sometimes it needs to be replaced. Try to mechanically move the lens in and out by gently twisting, pushing and pulling. If that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
May 03, 2010 | Canon PowerShot A1100 IS Digital Camera
Camera won't turn on completely - the error message is 'lens error'
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Sep 20, 2009 | Cameras
Canon S3 Lens Error
There two possible scenarios:
1. Sand particles got stuck in the internal lens mechanism. Try in remove them with compressed air, blowing it through the camera lens openings. If this does not work, then here are the bad news.
2. Either the lens internal gears are damaged, the ultrasonic motor is damaged, or sand particles are really stuck inside the lens.
It does not matter which of the three reasons are casuing the problem, but the camera needs to be opened by a qualified technician, defined thereason of the failure, and quoted the repair service, unless you are willing to do it yourself, but it requires a complete disassembly of the camera, and I don't recommend it unless you have the experience and skills in fixing electronic devices.
Best regards,
Jul 12, 2009 | Canon PowerShot S3 IS Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Len Error: M525-22
The same thing happened to me. I dropped my camera and now it is giving me that message and the lens wont go back in. My camera is a: Canon PowerShot SD780 IS DIGITAL ELPH
I need help also :(
Nov 12, 2007 | Cameras
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
49 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
