Question about Makita 7" Electronic Sander - Polisher 9227CX3
Speed varies on its own
No what speed it indicates on the rpm knob the speed varies from high to low on its own
  • 154 Answers
You must replace the speed control module. Any Makita service certer can supply you with the proper parts.
Posted on Apr 15, 2009
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
How do i bring my idle rpm down on my 2002 cam 88
Ensure that the engine is warmed up to normal operating temperature and the enrichener knob is pushed all the way in BEFORE adjusting engine idle speed. It is possible for a properly warmed up engine to idle above the normal idle range of 950-1050 RPM with the enrichener knob pulled PARTIALLY OUT. If the bike has no tachometer attach one or attach a DIGITAL MULTIMETER equipped with an RPM INDUCTIVE PICKUP over front spark plug cable to monitor engine RPM. Then start the motorcycle engine and let it run until it reaches normal operating temperature with enrichener knob pushed fully in (enrichener closed). Then set the idle speed to 950-1050 RPM using a special CARBURETOR IDLE ADJUSTER and tip. Turn clockwise to increase idle speed and turn counterclockwise to decrease idle speed. The throttle stop screw in on the right or front side of the CV carb.
May 30, 2014 | 2002 Harley Davidson FXDL Dyna Low Rider
Rpm problems with no check engine light on
If the RPM is high check for a vacuum leak. Examine all vacuum hoses for cracking or disconnections. If no problem is found, spray carburetor cleaner on the intake manifold and any other gasketed areas on the top of the engine. If, when spraying, the engine RPM fluctuates, then suspect a gasket leak where the spray is entering the engine. Also check throttle body for sticking. Clean it with carburetor cleaner.
Low RPM could indicate a clogged fuel filter, low gas, dirty or bad fuel injectors. If engine idle is low because it is running poorly (e.g., a misfire), check engine for misfire. Misfires can be caused by bad spark plugs, bad spark plug wires, bad fuel injectors, a bad coil pack, low compression in a cylinder, etc. Check the obvious cheapest things first.
If RPM is varying up and down, check Idle Air Control Valve (IACV) for sticking or obstructions. You may need professional help at this point.
Feb 05, 2014 | 1996 Ford Mustang
What should the pressures on the low and high side of the air conditioner read ?
low side should be about 30 psi at idle speed, high side 120 to 180 psi depending on ambient temp. higher temp, = higher pressure, as you increase engine rpm to say 1000 low side should drop to 10 to 15 psi & high side should increase about 30 psi. If high side goes over 280- 300psi you have contamination (air) in system or over charged with refrigerant. you will need to recover freon, evacuate & recharge system with proper amount of refrigerant. If the low side drops below 0psi or into vacuum then the refrigerant level is low, you will have to check for leaks , repair leaks & refill refrigerant.
Hope this helps
Paul T
Jun 01, 2011 | 1997 Chevrolet Suburban
How to change a starter
Starter - There are like 2 or 3 bolts on most starters that are long and go into the engine block. Then there is the electrical positive connection which should be removed only after the battery has been disconnected to avoid shock and fire caused by a short in the electrical system when disassembling or assembling (warning: this a safety measure designed to keep you from hurting yourself or the car). Assembly is the reverse of the removal.
TESTING No-Load Test Make the connections as shown in the illustration. Close the switch and compare the rpm, current and voltage readings with the specifications found in the chart located in this section. Fig. 1: Proper connections for the starter no-load test 87952035.gif
  • Current draw and no load speed within specifications indicates normal condition of the starter motor.
  • Low free speed and high current draw indicates worn bearings, a bent armature shaft, a shorted armature or grounded armature fields.
  • Failure to operate with high current draw indicates a direct ground in the terminal or fields, or frozen bearings.
  • Failure to operate with no current draw indicates an open field circuit, open armature coils, broken brush springs, worn brushes or other causes which would prevent good contact between the communtator and the brushes.
  • A low no load speed and low current draw indicates high internal resistance due to poor connections, defective leads or a dirty commutator.
  • High free speed and current draw usually indicate shorted fields or a shorted armature.
Jul 21, 2010 | 1990 Chevrolet Cavalier
The engine 4M41 is overheating heating on hills
if you drive on hills at high rpm ur engine temp. will surely shoot up due to the load on ur engine while trying to gain the desired speed/ u should not drive uphill with high rpm try to maintain low speed with low rpm
Apr 08, 2010 | 2000 Mitsubishi Montero Sport
Macculloch 14'' (350)chain saw,and cannot get my saw to fire up there are three adjusting screws marked T L H how many turns back for each screw from the closed position to enable a rough setting to fire...
t is your throttle stop
l is your low speed jet for fine tuning low rpm.s and idel itself.
h is high speed jet.
basic settings for the L and H jets are one turn out / open
throttle stop will vary but once you have it ideling you can tune that one while you are holding the trottle then go back to the L jet till u got it running sweet. then re adjust throttle stop if necessary. now move on to high speed jet.
Mar 03, 2010 | Measuring Tools & Sensors
1988 Dodge Aries K 2.5L Engine Trouble and codes
CODE 14
Trouble Code 14 indicates that the Coolant Temperature Sensor (CTS) is reporting abnormally high readings. CTS is used to control fuel mixture, timing, idle speed, TCC and EGR operations among others. The thermistor used has a low resistance when hot, rising as the coolant cools. This error then, indicates a very low resistance in the CTS circuit.
CODE 15
Trouble Code 15 indicates that the Coolant Temperature Sensor (CTS) is reporting abnormally low readings. CTS is used to control fuel mixture, timing, idle speed, TCC and EGR operation, among others. The thermistor used has a high resistance when cold, lowering as the coolant warms. This error then, indicates a very high resistance in the CTS circuit.
CODE 33
Trouble Code 33 indicates that the Mass Air Flow (MAF) sensor is reporting more air is entering the engine than makes sense based on RPM and TPS. The MAF sensor produces a frequency output; around 30 Hz at idle to 150 Hz under acceleration. The frequency varies proportionally to airflow. The ECM monitors the frequency and thus determines airflow into the engine. Typical idle MAF is 5 to 7 grams per second.
Mar 30, 2009 | 1988 Dodge Aries
Heater blower only blows on low
This could be a few different things:
1.Check the power and ground connections on your blower motor, corrosion can cause high resistance and a slow blower speed.
2. Check your available voltage at the blower motor on the different settings. it should vary with high supplying 12volts, make sure to do this check with the blower motor still plugged in.
3. Connect the blower to a 12v power source and see if it runs at high speed.
If all else fails i would check your resistor pack, i would not suspect this because when it fails you usually just loose all speeds except for high, but it could happen.
Feb 25, 2009 | 1999 Chevrolet Silverado 1500
Engine idling varies depending on light or aircon is on/off
dude its normal for first start or cold start that the idle is ok but it must high than normal... its normal because the engine is warming up it self... when it gets warm, the idle speed will return normal idle... your engine is 1200cc, it has not much HP for a great load... and i know its a carburatored engine and its an old engine, your head lyt and a/c fan and aux fan and all the electrical system on your car, uses the HP of you engine and its a lot of load to the alternator driven by the engine to generate an electricity they need and thats why the engine rpm speed lowering down to dead and its shake. thats why when you use your lyts or all electrical, you engine is weakening... the best remede is adjusting you idle speed... its located behind the carburator.. its a small black knob.. just make a twist each eighter way and you'll find out if your idle rpm speed ts incresing or decresing.. just increase it and try opening your lyts and other electrical, if its still shaking then adjust it a little more
Aug 26, 2008 | 1994 Honda Civic
Makita 7" Electronic Sander - Polisher 9227CX3 Logo
121 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
