Question about Dishwashers
Hi, My hoover hfi 3015 dishwasher is not getting hot when on wash cycle also some time it doesn't fully drain can any one help regards scotty
  • 641 Answers
SOURCE: tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Posted on Jul 02, 2006
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
SOURCE: GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
Posted on Aug 01, 2008
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
Hoover HFI 3015 integrated dishwasher beeping on each program cycle selected
Check out the micro switch on the door seems to not indicate that the machine is properly closed or your outlet pump is blocked and needs to be cleaned out,cause it is clogged up and cant remove water properly
Jan 06, 2014 | Dishwashers
Hi. I have a kenmore Washing Machine model 27062601 It doesn't finish the cycle. stops wen is washing, then I have to open it and start the cycle again. some times this works, some times don't. ...
Hi xochipiliti,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Kenmore Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
My Dishwasher has a rapid flashing light
I get the same problem with a pepeating beep warning. Only solution I've found is to switch it off using off button then switch it back on. It waits a few seconds then finishes the program and drains. The dishes still seem to be quite damp after. Hope this helps
Jul 12, 2010 | Hoover Dishwashers
Hi my hoover 6612 dishwasher does its pre-wash but then when the light for wash comes on it does nothing. I wondered if it might be a capacitor which needed replacing but I can't find one - any ideas??
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
Check start capacitor on the left side of the wash motor
Mar 13, 2009 | Dishwashers
Dishwasher not draining
Hello Tony,
Before pointing the finger at the pump.. try these few things first..
Make sure your drain screen filter is free of food by products and not restricting water flow out
Make sure your drain hose is not pinched, clogged or restricting water flow out
Make sure the place your drain hose drains into is not restricting water flow out
If you have water remaining in the base of the wash compartment, bail out as much as you can then run a dishless cycle to see how much water remains in the comaprtment. If it drains completely, then you should be ok.. if not then, you may have a bad pump, obstruction in the line into or out of that pump.. Let me know how it goes after you run thru the checks listed above and the outcome of the wash cycle. Hope this helps..
Regards
Oct 11, 2008 | Dishwashers
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
224 people viewed this question
Top Dishwashers Experts
