Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
Flash pre-firing like mad?
Just purcahsed the Canon Rebel XS. When I go to take a picture, using any mode with flash on, it pre-fires like mad. It just blinks while it focuses. Is this a setting issue? Or a defect?
  • arb1989 Mar 08, 2009
    When I say pre-fires...I mean the flash prefires like crazy!
    Problem Solver:
  • 17 Answers
It is your camera using the flash to assist in focusing, if it bothers you you can change it in your menus, I have a XTi so yours will differ slightly.
Switch your camera to "P" mode.
Press "Menu" button.
Go to setup menu 3
scroll down to "Custom Functions (C Fn.)"
Press "set".
press to the right until you find "AF - assist beam"
Press "set".
And press up or down.
Set to "Does not emit"
press "set"
Press "menu" button twice.
Posted on Mar 16, 2009
Camera won't shutter
So that any responder does not repeat steps you have taken, what have you attempted to do to solve this issue?
  • Turning on and off the camera sometimes will fix it.
  • If you are in AF mode and the camera cannot get focus it will not fire the shutter.
  • If it is in a low light area, reason the flash popped up, and the camera cannot find something to focus on it will not fire the shutter.
There are a number of things that can cause this, some nothing to do with an errant camera.
Cordially,
Jun 20, 2014 | Canon EOS Rebel XS 35mm SLR Camera
Auto flash does not pop up on 7D
Does the flash fire? If it fires when closed then it is a mechanical issue with the release mechanism. Probably got something jamming the release. Unfortunately this requires opening the camera. Best to consult your nearest canon dealer if your not confident enough to try yourself.
Jan 05, 2014 | Canon EOS Digital Rebel XS / 1000D IS...
Rebel T3i built-in flash does not fire
Most Canon DSLRs have a switch in the hot shoe (if you look under the spring plate in the hot shoe one one side there is usually a small white shaft sticking up from underneath the top cover). Sometimes because of spillage etc. this shaft sticks down and the camera thinks that there is an external flash installed so it won't operate the built in flash.
In your case I would be more suspicious of the flash board. Does the flash symbol in the viewfinder light up? When you fire the camera does the symbol go out but the flash doesn't fire? This is a pretty common sign of a bad flash board.
A third possibility would be a broken flash tube. Has the camera been impacted?
Put the camera's mode dial on 'P' and push the flash button on the side of the mount/front cover. Does the flash pop up? Does it fire now? On the P,A,S,M setting the flash fires all the time if it is popped up; if it is one the green rectangle or other setting it only fires if there is not enough light.
Finally reset the menu to factory default in case something is selected that is causing the flash not to fire.
Apr 30, 2013 | Canon EOS 600D Rebel T3i Digital Camera
HOW TO TURN ON FLASH
Flash should pop up automatically when you operate camera in easy mode (green square on dial selector) in low light conditions. If using in manual modes press the button on the left side of the lens mount. To fire the flash without taking a picture press the button used to zoom out when viewing pictures.
If your flash does not work at all then there is probably a fault with the charging circuit or firing circuit.
May 11, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
I have a Vivitar 285HV flash and I'm wondering if the firing voltage is low enough to use with a Canon Rebel Xs digital camera?
According to Vivitar, the 285HV has a trigger voltage of 12V, which should be safe for use with modern digital cameras.
Mar 22, 2011 | Vivitar Cameras
My canon rebei xs will not work at night,when it is too dark it will not take pictures, like the flash will not work or fire. WHY
use the manual mode or aperture priority. or use automode. if still not working reset the camera to default
Oct 23, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My 1000 d does not work in AF mode. The flash fires several times a word appears busy. Siapa poer not to take the pictures
its main board problem eighter you can solve with special tool with latest service firmware update
or you can replace new main pcb,
Aug 05, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
I just bought the 430ex II flash and it won't fire on my Rebel XTI.... i read the manual but I'm not sure whats wrong, have any advice?
I assume that flash is turned on. 430ex flash will fire automatically only in AUTO mode. On manual modes you mus manually force the flash to fire.
If flash doesn't fire at all, consider to claim the vendor or let the vendor to check the flash mounted on your camera.
Aug 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Camera does not fire external flash
Is it in manual or auto modes (camera)Try resetting the camera back to factory defaults as a first step.
Feb 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
118 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
