Question about Scytek Electronics ASTRA7E7 Car Alarm - Keyless 2way Lock - Unlock
Phillips head unit
Well i bought a cd player off a freind, he took it out of her car then i put it in mine.. an its asking 4 a lock code.. iv tryd an i cant figure it out.. can u plz help me.. its a 45/4 watt phillips car head unit... plz help asap...
  • arn_rox89 Mar 08, 2009
    no he doesnt no it he has had it 4 ages an 4gets he has neva had 2 put it in his m8 put it in his car an put tha code in... he does nt hav a clue thanx neways
  • 36 Answers
Ask your friend for the code, since the friend who you have bought it from programmed the code it's(radio) asking for.
Posted on Mar 08, 2009
  • Gilbert  de Jong
    Gilbert de Jong Mar 08, 2009
    Since he doesn't know it...maybe if there's a philips dealer not too far away from you, they can reset the code for you to 0000.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How do you put codes into the radio cd player for a renalt scenic 2000 modle
hi what you is supply the make of it ie phillips, sony, that sort of thing and the serial number on the head unit then i might be able to help with a code, although, if you have imputed the code incorrectly 3 or more times the radio will become locked out and be unusable as this is an anti theft thing to make it unsaleable to thieves....if you have not put it in 3 or more times then we can see if i can supply a code for you
Feb 26, 2010 | 2000 Renault 181
Kenwood head unit not powering up help please.
find your remote wire. it would help to know the type of car and the kind colors of wires your using as your 3 main wires.
normally in most chevy and fords they are yellow 12 volt.
black as ground.
red sometimes even a tan as your remote start.
deff check your start
May 09, 2009 | Kenwood KDC-W6027 CD Player
Ford 6006e rds eon cd radio - won't switch on
remove the head unit from the dash, unplug the main connector from the rear and then plug back in. the unit seems to reset itself and asks you for the security code, should work afterwards. must be common fault as ford dealer new exactly what to do when i took mine in.
Apr 01, 2009 | Car Audio & Video
Car Audio Security Theft and lock and unlock code
You will have to take it to a radio shop and have them reinstall the code nothing you can do about it sorry
Feb 11, 2009 | Kenwood KDC-MP4032 CD Player
Daewoo Car CD Player Code
try codes 6620,0191,6012,4797,or 1305 i will try to find some more but i need the seiral number to know for sure they have diff ones for each unit
Dec 10, 2008 | 2001 Daewoo Lanos
Security code Lockout
I had a similar issue with a head unit in a newer Volkswagen. There was an unlock code burried in the vehicle's owners's manual.
Since your stero is an aftermarket model, I would bet the unlock code is in the manual for the head unit.
Sep 09, 2008 | Kenwood KDC-MPV7019 CD Player
Dual XDVD710 Car Video Player
There isn't a code but there is a way when you wire it. DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 31, 2008 | Dual XDVD8181 Car Video Player
Locked renault clio 2001 cd/radio player!
to enter your code when the cd player displays error leave cd player switched on and after 20 mins or so i will display 0000 then you will be able to enter your code this happens when some 1 has entered the wrong code
May 17, 2008 | 2000 Renault 181
Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Jan 09, 2008 | Kenwood KDC-322 CD Player
Can't play CD or DVD
OK..I spoke to a representative at the Toshiba service center and was given the most silly procedure to follow....but IT WORKED.
Here goes:
1. Unplug the unit.
2. Remove the batteries from the remote
control
3. Press and hold each button on the remote for two seconds. Not all at was, but one at a time. Do EVERY button.
4. Put the batteries back in, plug in the unit and away she goes!!!!!!
Toshoba guessed that there is a static charge in the remote that is discharged using this method.
I know.....IT WORKED for me.
Oct 16, 2007 | Toshiba SD-5000
Scytek Electronics ASTRA7E7 Car Alarm - Keyless 2way Lock - Unlock Logo
197 people viewed this question
Top Astra Vehicle Parts & Accessories Experts
xxxxxx xxx
Billy Mac
Are you an Astra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
