Question about Maytag PYE2300AY Electric Dryer
Maytag model LA- 510 washer. Not spinning fast enough, Clothes come out too wet and water sometimes left in bottom of drum. Belts were changed. No help. Also, machine makes a large ''clunk'' sound at end of cycle. Am told that noise is related to brake system. Could it be causing spin problem?
  • 36 Answers
The cluncking sound is not a brake system since there are no brakes, but the stabilizer of the drum. as when it stops turning the whole weight of the drum 'hangs' on the stabilizers. That might also be the problem with not spinning fast enough, although I think that its not spinning fast enough because there's too much water inside. I would check the drain hose and drain filter, either one of these two are clogged up, and therefor not letting the water out.
hope you'll find the problem soon.
friendly greetings............Gilbert.
Posted on Mar 08, 2009
All cycles work but clothes come out wet, top loader model# AAV7000AWW is there a lint trap that needs cleaning?
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
Feb 07, 2016 | Washing Machines
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Clothes are dripping wet after spin dry cycle
You may have a bad belt not spinning the drum fast enough or not enough tension on the belt due to worn motor springs.
Jan 02, 2010 | Maytag PAV2300 Top Load Washer
My washer doesn't wring the clothes fully.
It's not spinning fast enough because of a loose or worn belt on the motor. Post back with your model number and I may can find a diagram of your washer to help you.
Sep 04, 2009 | Maytag Performa PAV2200
Water left in clothes
The shaft was designed to rotate into 2 directions: one for agitation, one for spinning. The spinning direction is controlled by a mechanism from the clutch engagement. When your plastic pulley wears out, it effects the mechanism to spin. The driving force for spinning is slipped, therefore the spin is weak As a matter of fact, the water remaining in clothes n in turn discharges to the bottom tube
Jul 02, 2009 | Maytag Washing Machines
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Beko wma 510 washing machien leaving clothes un rinsed and wet.
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Washing Machines
Mav6260 washer will not spin
the belts on these units will streach, and alot of the early unit had bad belts.
the unit should spin with or with out water in the spin cycle
also the thrust bearing on these units go bad often.
this is a magic chef washer with the maytag name on it.
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PYE2300AY Electric Dryer Logo
270 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
