Question about Microsoft Multimedia Keyboard/Wireless intelliMouse Explorer K5000001M0300001
How to use the function keys on the wireless keyboard 1.1?
Need help using the F keys on my wireless multimedia keyboard 1.1
    Guru:
  • 829 Answers
Follow these steps:
  1. Run an AHK script. Make sure this script uses the keyboard hook (#InstallKeybdHook).
  2. Right-click on the tray icon and select Open.
  3. A window will appear. In the menubar, select View >> Key history and script info
  4. You will see a list of the last twenty key events (and mouse events, if the mouse hook is installed), including their virtual key numbers and scancodes. Pressing F5 will refresh this list.
  5. Anything that you can see in this list can be captured and/or reproduced in AutoHotkey. However, not everything can be seen here. So, to test, press the key, F Lock in this case, and then press F5 to refresh the list. If AutoHotkey couldn't see the key, the list will be unchanged except for the F5 key you just pressed. If it could, though, it will be the last key on the list (excluding F5).
Posted on Mar 08, 2009
I use MacBook Pro (OS X version 10.5.8) in combination with LCD TV, wireless mouse and new Apple wireless keyboard. The problem is that function keys of the wireless keyboard do not respond in a same way...
Make sure to run all available software updates as there's probably a firmware update for your keyboard you need to download.
If there isn't or the problem persists afterwards, you'll need to go into Apple Menu > System Preferences > Keyboard and Mouse > Keyboard and uncheck 'Use all F1, F2 etc. keys as standard function keys.'
Nov 06, 2010 | Apple Wireless Keyboard
Microsoft wireless keyboard 4000 and wireless mouse 5000. Installed software and recognizes mouse and keyboard but only funtion as standard devices, none of the bells and whistles work. open software and...
If you want to check if the software is installed correctly and the keyboard is working fine try using the multimedia key. If you are able to use the multimedia keys for reducing and increasing the volume or mute the sound that means it is working fine.
If you are trying to configure the Favorite keys then you will have to select the buttons from the software and link it to the particular program of your choice.
Open the software application
Select the button that you want to configure
Click on the browse button to select the program of your choice to open with that button.
Jul 21, 2010 | Microsoft Wireless Optical Desktop 5000...
SHIFT KEY DOES NOT FUNCTION ON ROCKETFISH WIRELESS KEYBOARD ANY SUGGESTIONS WOULD BE APPRECIATED
If you have another keyboard try using that and confirm if that works properly.
Incase you don't perform the below mentioned steps :
Click on start
Click on run
type CMD
test the shift keys on the black window.
If it does not work here it is a problem with the keyboard.
Jul 20, 2010 | Laser Rocketfish Wireless Multimedia...
Cannot use right side numbers of the keyboard, other functions ar
I'm not sure what keyboard you have but there should be an "Fn mode", "Mode" or similar button on your keyboard, it should be the same color as the function icons on your other keys. This is usually used to toggle between the different modes. If this doesn't work or only works while your holding it down then you'll need to find the setting software for your keyboard. It's most likely in with your other programs or in Control Panel, some will put an icon in your task tray that you can double click or right click to access them.
May 02, 2010 | HP Multimedia Cordless Keyboard/Mouse...
Multimedia keyboard on function keys. Functions work with a key "Function" How to change "Multimedia keys first" on "Function keys first" ???
You can change the settings by going to BIOS. To go to BIOS, restart the system and as soon as you restart, start tapping the <F2> key located on the keyboard. This will take you to BIOS.
You can use the Function Key Behavior setting in the System Setup (BIOS) utility to configure the media control keys. The options in the Function Key Behaviour setting are:
Multimedia Key First - This is the default option. Press any multimedia key directly. For function key, press <Fn> + the required function key.
Function Key First - Press any function key directly. For multimedia key, press <Fn> + the required multimedia key.
Nov 01, 2009 | Dell Inspiron 1545 Notebook
Logitech wireless keyboard MX 3200
Normal 0 Are you using Windows Vista? If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
Hope this helps. Bud
Nov 06, 2008 | Logitech LX300 967427-0403 Black 86 Normal...
Microsoft Multimedia Keyboard 1.1
my microsoft wireless multimedia keyboard 1.1 does not function at all
Sep 02, 2008 | Microsoft Multimedia Optical...
Natural Multimedia Keyboard
2. When the Printer Properties comes up, CLICK on KEY SETTINGS.
Jan 03, 2008 | Microsoft Multimedia Keyboard/Wireless...
Funtion Keys not working
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Hope this will help some. Bud
Oct 19, 2007 | Dynex Wireless Keyboard/Optical Mouse...
The Print key is not working
it depends what system you are running cetain programs and windows operating systems dont accept this shortcut
try going into controll panel clik keyboard and make sure hot keys are on
the only other reason is if you have eny other wireless functions running these can disrupt the signal from the keyboard to the computer turn off all wireless items and try agen
if none of these work try replacing the keyboard as it should work as long as hotkeys are on and the operating system you have accepts this function
Oct 18, 2007 | Microsoft Wireless Optical Desktop Pro...
Computers & Internet Logo
505 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
