Question about Goko Camera Ltd Macromax FR-350 35mm Point and Shoot Camera
Screen problem of mp4
I have a mp4 ,i was doing downloading but didnot connect it in switch off mode i got a problem that my screen is not appears even it becomes switch on but no screen
Calibrate the screen
Posted on Jul 12, 2011
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
STEP 1 - Connect the Sansa player to the PC
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
How to download music video from pc to mp4?
Hello
The Internet is full of great places to find MP4 downloads. Check out sites such as iTunes to find a video or file you like, and then click the download button.
A dialog box will appear reading, "You are about to download the file "name_of_file_you_are_downloading _will_appear_here", are you sure?" Click "OK" to start downloading.
A File Download pop-up screen will appear again, asking "Do you want to open or save this file?" Click the SAVE button to save the file to a specific location on your computer (be sure to remember where you save it!).
Once you've saved the file to your computer,connect your mp4 player to your computer,go to "my computer"you will see your mp4 player among the list of drives.Click to open the drive then you can click on the file you downloaded and drag it to your MP4 player and enjoy!
If the file you've downloaded isn't in the correct format for your player, you may need to convert it before adding it to your MP4 player. Basically, you'll repeat Step 3, and save the download to a file on your computer, then convert it and add it to your MP4 player. See your instruction manual for details, or search the internet for a free MP4 converter to reformat the file. This process is quick and easy and should only take a few quick mouse-clicks.
Good luck
Jan 15, 2011 | Audio Players & Recorders
Mp3 and Mp4 download problems
how can i do to download music to computer send to my mp4
Jan 21, 2010 | SVP HDDV-2500 Camcorder
Dv Mp4 Mp5 player cannot recognize by PC
Your younger brother should be doing your chores for the next month to repay you for wrecking your Mp4 player - I am guessing formatting it erased everything including the operating software.
The Mp4 player like most things is a small computer and computers are just so much junk if they don't have an operating system.
I fear your player will remain junk unless you can find a suitable operating system and persuade the player to accept it.
I suggest you contact the supplier for advice in the first instance, you could be lucky and find them helpful.
If that fails then asking around all the nerds and boffins you might know of could produce results, as could some general online research.
May 17, 2017 | Audio Players & Recorders
Poor video recording in sony dsc w30
i think you can have a trial of another kind of converter.
Use http://www.downloadvideos-convert.com/download-videos-music
1. Download Video Download Studio, install it.
2. Go to the interface, you can download (Automatic capture) the YouTube video there directly. Tab Download to
Convert, you can also click "Add" button to upload the videos from computer. You can also edit video by trim and crop
functions.
3. After the video display on the Video Download Studio, click "Profile" and choose "General video", then select an MP4
format. Set destination file, clicking Convert button to complete the task.
Not only convert video to MP4, but also support batch conversion. Safe and easy to operate. No Viruses, No Spyware, No
Adware. Do not hesitate. Have a try!
Mar 15, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Tevion Mp4 player keeps connects and disconnects during downloads.
Well i think maybe your usb cable might be loose or the mp4 player is damaged. I really want one though...
Jul 31, 2008 | Audio Players & Recorders
Charger will not fit anymore
If you got a USB cable with the unit, you can connect to your PC and recharge the battery that way. Just be sure to have the power switch turned ON. The screen on the player will indicate its connected and you should see the battery indicator in the lower right corner showing a charging condition (bar moving)
Feb 12, 2008 | Audio Players & Recorders
CRAIG MP4 plus video player- disk error message appears.
make sure the songs you download are right for your mp4 player because Limewire only plays mp3 songs. so i would go on the internet and find a music site that has mp4 songs
Jan 28, 2008 | iLO (2 GB) MP3 Player
Nokia 9500 doesnot boot
hi for this problem == plz check this out www.nokiausa.com/support/phones hope you can get your cell back as it was! GOOD LUCK
Apr 28, 2007 | Nokia 9500 Communicator
Goko Camera Ltd Macromax FR-350 35mm Point and Shoot Camera Logo
37 people viewed this question
Top Goko Camera Ltd Cameras Experts
Are you a Goko Camera Ltd Camera Expert? Answer questions, earn points and help others
