Question about Air Tools & Compressors
Air compressor is louder than normal - Air Tools & Compressors
  • momakmiller Mar 11, 2009
    My compressor kicks off and on at different times to. It is also louder than usual, I am thinking I may need a new one because sometimes my rearend will become a lowrider in just minutes, even while driving down the road. I have to shut the suspension air compressor switch off and wait a few minutes and then turn it back on for it to engage. I dont really think I have a hole or anything in hoses or in my air bags because I would think it would be a lowrider all the time. I think the compressor is trying to go out and may need a new one but I want to look at all my options first. Any suggestions or answers?
  • Dean
    Dean May 11, 2010
    Is it a new compressor or the same compressor that just suddenly got louder?
    What type/model?
    Scholar:
  • 89 Answers
LOOSE BELTS MAKE ALOT OF NOISE ( IF YOU HAVE BELTS.)THEY CAN EVEN SOUND LIKE ROD IS KNOCKING SOMETIMES. DONT KNOW WHAT KIND YOU HAVE.
Posted on Mar 14, 2009
Kenmore elite french door refrigerator and freezer not cooling
Check the compressor start device. The fans will be running and the compressor fan will be running but the compressor is problaly not running. If it is then it could be the compressor itself that is not oumping.
Mar 25, 2014 | Kenmore 73502 / 73504 / 73509 Bottom...
Our Maytag upright freezer motor is making a louder noise when it runs. It used to be a quite little hum, now I can hear it through the wall in the next room. What should I do, It has a 10 year warranty...
try to clean your condenser unit or check your condenser fan if working normally possible your comp.working hardlydue to poor circulation of air cause of high pressure of unit.or possible wear and tear of mechanical parts of long years of uses need for replacement of compressor.
Mar 06, 2011 | Refrigerators
Problem with model CKL36-1K. When thermostat kicks on, The outside unit sounds like it starts to run normal and then starts to get louder and louder resulting in a screaching like noise. The fan does not...
The problem could be the capacitor for the fan motor or the fan motor itself. Turn off the power and use a long screwdriver to see if the fan will turn freely. If it doesn't it needs to be replaced. If it spins freely then check the capacitor. You can do that with a multimeter with the capacitor check function or take it to a heating and air supply and they can check it for you. If the capacitor looks swollen then it is bad. Some units use a three terminal capacitor that is connected to the fan and compressor. Make sure you check the fan side but it wouldn't hurt to check both while you're at it. If the capacitor is good then use an ohmmeter to make sure the fan motor windings a not open or shorted. The increasing noise probably comes from the head pressure building on the compressor because the fan isn't running.
Aug 31, 2010 | Goodman CKL36AR36 Air Conditioner
Sharp winning or piercing compresser noise. is it normal? maytag refrigerator model # ptb1954grw.
maytag frig is noiser than other brands . amana also and jenair and majic . all made by maytag. this units have a compressor noise louder than most . there comp are larger and some what louder . but i would say you have a normal maytag .. mm i was maytag largest dealer in utah for many years and your statement is very common .. some times the copper lines or fans cause louder noises . so if to loud you should have ti ck'ed . mm
Aug 10, 2010 | Maytag Refrigerators
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
Motor is running continuously and is loud
The coil ubder the frig could be filled with dust/dirt and no air is flowing over it to remove the heat. This will causecontinuous running and force the compressor to work harder and louder. A loss of some refrigerant (freon)will cause continuous running but not likely to cause louder running. The fan motor in rear of frig at the compressor could be worn out and running slow or stopped and without this air flow the compressor never stops and runs loud. Also, the door gaskets (especially the bottom part could be torn and bot sealing well; this will cause continuous running but not likely loud running. Goodluck, Macgivor
Oct 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Have a 2000 Ford Ranger SuperCab, 4.0 4x4 AirConditioner isnt blowing air. Compressor seems as if it is coming on and working properly. Airconditioning unit inside truck sounds Normal (ie: turn fan on,...
I had a problem with my 2000 ranger when I bought it. Air was coming out of defroster vents. Check for a vacuum hose that may be off under the hood. It uses vacuum to open the vents.
Aug 01, 2009 | 2000 Ford Ranger SuperCab
No psi
A louder motor usually means that it is running at a higher rpm. The most likely problem is bad seals around the compressor pistons. Once there is enough resistance to the seals they will begin to fail. As for a manual the best place to check is a CH authorized repair shop. Sometimes your local lawn mower shop will be able to assist you with parts help
Apr 22, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
159 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
