Question about Samsung HCM5525W 55" Rear Projection Television
Samsung projection convergence issues
I have a samsung hcm5525w which had all 3 colors out of convergence.
i retouched all stk solder and while reassembling, i shorted R465 on the heat sink @ Q433.
When turned on, the set seemed better converged, although it was now zoomed by almost 2x.
i replaced the stk's with ones from another identicle board with no avail.
i replaced the stk's with what i was told were "sanyo original ic's."
Now the set will not turn on, just the red blinking 20 sum odd times.
I know i need to test several resistors, a couple pico fuses, and possibly the flyback.
Im just not sure which ones and their values, i do not have the schematics.
any help would be appreciated. ----Jason
  • 5 more comments
  • carrgo81 Mar 20, 2009
    turning it off does not help, since my last post, i have replaced one pico fuse with no result, im not sure if it helps, but when i press the up, down, left, right buttons on the front panel and sometimes i get the no signal "fuzz" noise briefly. I have a descent multimeter, better than average hakko iron, and now a slight bit of frustration. The set worked (but skewed) untill i replaced the ic's and; viola! 85lb. horse pucky paper weight on casters.
    doesn't help, has anyone read the first part of the thread? i've covered the basics. i've checked 2 pico's, replaced 1, replaced both ic's, and checked all large resistors, somethings tripping the protection still, i'm not sure how to check the flyback, and i've shorted a large resistor which is still continuous...???
    i've checked the resistors next to the ic's, seem close to tolerence
    i've already replaced the stk's, and i'm not familiar with the sub-deflection board
    still no help
    i still have not recieved any answers that are doing me any good?!?
    what should i look for in the power board?
  • 173 Answers
Hi Jason! In your case your right, the most probable cause of the red color is something to do with the flyback. GOOD LUCK! thanks
Posted on Mar 20, 2009
    Master:
  • 497 Answers
I dont know if these sites wud help u with the schematics...but plz do check it out
http://www.eserviceinfo.com/equipment_mfg/Samsung_2.html
http://www.eserviceinfo.com/list.php
Thanks for using Fixya
  • 483 Answers
I just found a usefull link that contains teh circuit info .. might wanna check ??
http://sci.tech-archive.net/Archive/sci.electronics.repair/2007-
  • Sid
    Sid Mar 20, 2009
    a) A shorted turned in the primary winding.
    b) An open or shorted internal capacitor in secondary section.
    c) Flyback Transformer becomes bulged or cracked.
    d) External arcing to ground.
    e) Internal arcing between windings.
    f) Shorted internal high voltage diode in secondary winding.
    g) Breakdown in focus / screen voltage divider causing blur display.
    h) Flyback Transformer breakdown at full operating voltage (breakdown when under load).
    i) Short circuit between primary and secondary winding.
  • Sid
    Sid Mar 20, 2009
  • 10,594 Answers
If TV is not messed up, just put back old STKs and check does TV power up?
If yes, then new STKs are bad. And if TV still in error blink status then you surely need related service manual to test power supplies going in to convergence board.
    Sergeant:
  • 300 Answers
U will need to check out the ic and capacitors.with multimeter and soder the faulty ones with the soldering iron. but as there are several components to check out.its bit too professional and techical/i suggest you to get it checked at local repair center.as it would not be too costly to get it repaired.because the faulty ic and capacitors are not very costly.as the local repair center have all the required spares to replace and check out.as its worth getting it fixed.
    Brigadier General:
  • 8,619 Answers
Hi
Try to check for the resistors placed near stk ICs . Check them when the Tv is turned off.
    Sergeant:
  • 320 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
click the link directly
and get all the required instructions
  • 412 Answers
Turn off your TV for 30 mins. and try one more time...
  • 1,170 Answers
Replace the convergence ic's with STK392-040. If this does not fix the problem replace the sub deflection board.
Here is the board schematics :
http://manuals.electromaniacs.com/file.php?id=21536
I have a couple issues. First, my screen is yellowing from the sides inward, and second, the picture seems a bit "blurry", even though it's set to 1080i and getting a signal from an HD...
The tv have a problems known as a convergence pictures problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes all of these problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 31, 2011 | Samsung HCM5525W 55" Rear Projection...
Images show double images like shadows
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergence board to fix the tv convergence board to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole convergence board for the replacement,might still have it.The DLP tvs AKAI and Samsung tvs used the same convergence board.Or the shop,will cost u like 300-350 for parts and labors.
Dec 17, 2010 | Samsung HCM5525W 55" Rear Projection...
Looks like i'm watching a 3 D movie 55"
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or a 3D pictures look alike?The tv have a dead convergence board.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are too.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | Samsung HCM5525W 55" Rear Projection...
I have a Samsung HCM5525W that distorts horizontally across the top and bottom after it has been on about 15min. Center of picture is fine.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
Dec 25, 2009 | Samsung HCM5525W 55" Rear Projection...
Color alignment
Please replace both convergence IC's.
May 27, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung tv #hcm5525w is on but has double vision
The problem sounds like it is the convergence output ic's are bad. I would let a repair man fix it.
Nov 14, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W 55inch
This is a convergence problem. It happens to all big screen rear projectors. The convergence output ic's need to be replaced. I would let a repair man do this.
Nov 11, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
558 people viewed this question
Jerry Greenberg
Jerry Greenberg
