Question about HP Officejet 4355 All-In-One InkJet Printer
Explane how to use fax. - HP Officejet 4355 All-In-One InkJet Printer
  • 27 Answers
Here is a link on how to make a fax:
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
Posted on Mar 08, 2009
  • 42 Answers
It is similar working on ur phone . Switch on ur fax machine. dial the destination no. . With the cover sheet at the top arrange other sheets carrying the information under the cover sheet in order and feed it to the fax machine feeding tray . The cover sheet is one which contains the recipient identification and ur identification in it
Fax from computer
First, you will need a USB fax modem. Then you use Windows Fax & Scan program to create/forward new fax documents, or even send a file as a fax or email.
Setting up your external modem to work with an internet telephone line is simple. Simply put a 2 way splitter into the internet modem telephone jack. Plug your telephone into one input and the external fax modem into the other. Then you can even dial from your computer routine telephone calls too.
Need more explanation? Let me know.
Mar 14, 2014 | Brother MFC-7460DN
Unable to remove on screen rec d in memory
Receiving Documents in Memory While Performing Another Task or When a Problem Occurs
If your fax is performing another task or encounters a problem when receiving a document, it
automatically stores the unprinted pages in memory, and the LCD displays MEMORY> as well as one or more messages. For an explanation of the message(s) and details
on the action to take, see page 64.
If you would like for me to send you the user manual, please send me an email to LBrown18062@hotmail.com Put CANON FAX JX200 as the subject and I will send it to you right away.
Oct 21, 2011 | Canon FAX-JX200
Redcare alarm system won't work with sharp
Yes you are correct.
What happens is most , not all things attached to the same line as the fax, that require monitoring will interfere with the incoming fax.
I can go through the technical explanations but it has mostly to do with the ammount of signal received to the fax and it not being high enough to turn on the fax.
The best explanation I can give you is to compare it to trying to use a TV remote with low batteries. It may be enough power but most of the time it will not be.
The cure for your problem is to seperate the fax from teh alarm system.
Unlikely any type of filters will work. I have run into this issue with alarm systems, credit card readers, etc when attached to the same line as a fax.
Aug 02, 2010 | Sharp MX-2300N Color Copier
Hello, Our Brother 5750e is displaying an error code of 7C. Is this a coomon problem and is there anything I can do here in house to remedy it. I have checked the manual and there is no explanation for...
worst case scenerio is your engine board has gone bad. first though, try a new brother brand DR400. a faulty/binding drum unit can cause this. usually happens with generic brands.
hth,
razors
Dec 10, 2008 | Brother IntelliFAX 5750e Laser Fax
Cant figure out how to set the fax at 1 ring or just fax
Here is the weblink which provides you a clear explanation of the solution:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00366238&dlc=en&product=3301296
Thank you.
Nov 29, 2008 | HP Officejet J5780 All-In-One InkJet...
Need a repair manual for the Xerox 2045 or 2060. Any ideas where I can purchase one? Thanks
. To place an order, please call 800-327-9753. Thank you for your cooperation.
Explane to them what you would like.
Apr 21, 2008 | Office Equipment & Supplies
Won't recieve a fax
Normally a receive problem is in the phone line. I will explane so you understand why I am saying this and not excusing the machine.
For starters as a resoution, make sure your phone line is plugged into the line slot and not a slot for a phone or answering machine. The slots I am talking about are on the fax machine.
Also if you have the fax on the same phone line with another device. An answering machine, a credir card reader, etc etc, make sure there isn't a conflict. Try just plugging the fax machine into that phone line.
Now to explane. When you send a fax, you manually turn on the phone line when you tell it to fax, Pressing that button energises a relay and just like picking up your phone receiver you turn the phone line on phisically.
When you receive a fax, it has to have the proper signal to electronically activate the fax/modem board.
Issues can be as simple as a bad phone cord between your fax machine and wall jack. They do build up resistance and cause problems.
3 issues are needed to receive a fax. The phone line Voltage must be correct, the phone line current must be high enough and there must not be a decibel loss.
A good example is a remote controle. You have old batteries. Well if you measured the voltage, it would still be 1.5 volts, but it can not deliver anough current to change a channel or adjust the volume all the time. If the line voltage is right, and your phone line it having a problem, it can't deliver enough current to turn on the fax, like turning on a TV with a remote, there is just not anough total power to activate it.
Remove everything else but the fax from the phone line, try it then.
Replace the cord between the machine and wall jack, Try it then.
If that doesn't correct it have the phone company test your line to the house, if thats ok, then repalce your wall jack.
99 percent of the time a phone line will be a problem.
Mar 21, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Fax machine phone connections
I beleive it's because they are grounding out on the fax, which then resets some of the functions.
Did you measure if there are any activity on those two lines?
V or Hz?
Jan 30, 2008 | Brother IntelliFax-2820 Laser Fax
HP Officejet 4355 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
