Question about Kodak EasyShare M1073 IS Digital Camera
My camera won't stay turned on
I have recently been to a sand island and come back and my camera is not working i have tried turning it on and off many times but the digital zoom on the front wont stay open and it turns itself off everytime what shall i do how can i fix it?
  • 1 more comment
  • floaty_momen Mar 12, 2009
    thank you, i had tried all those already from the help section in the book, will sort it through insurance now.
  • sarahorror Apr 29, 2009
    i have the same problem! i recently have been going to the beach. now my camera won't turn on or charge! the red light flashes like it has no battery.i have rechargeable batteries so i cannot just replace it.
  • Anonymous May 19, 2009
    Yep and me lol i have exactly the same problem, i was on holiday in spain on the beach took some pictures and put it back in the case then it wouldnt come back on again, i shall try the solutions, cant see much of them working though.
  • 98 Answers
Its possible that dirt, sand had got stuck between your lens barrel and the body and that why the lens is giving you problems.
You can try some of the following solutions to help you out:
1).Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
5: Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. Dont try very hard please.
Try the above and let me if its any help.
If the above does not help. Then you would need to take it to the nearest service center.
Posted on Mar 08, 2009
Vg-120 wont open
I know this is just southern inginuity but ours did the same after a trip to the beach. my husband took a knife and removed the outer rim, to loosen the sand out, then we had to tape the ring back on. still works. but if you don't won't to damage your camera, you might not want to do it that way.
Jul 27, 2012 | Olympus Software VG-120 Digital Camera
I recently won an E10 in an auction. I did not receive any paper work or anything with it, so I don't know a whole lot about this little camera. But what I do know is that when I turn it on, it go
There are other complaints all over the internet about this cameras' battery life. Are you using NiMH batteries or alkaline? If you used 8 you must be using alkaline. If they are heavy duty regular batteries you are using the wrong kind of battery. NiMh hold more power and last longer with a flatter power curve up till they are about done. Recahrging means not buying lots of batteries too. They should last for a long, long time; like a week or two at least. The manual and quick guide can be downloaded in PDF from
Jul 22, 2012 | Pentax Optio E10 Digital Camera
Camera wont focus
If it recently sustained a drop or other impact, the lens mech is damaged. With the lens out, visually inspect it to see if it may be slightly crooked or askew. If so, gently try to "pop"it back into alignment. If not, sand or other debris may be caught in the mechanism. While the camera is turning on and the lens is extending, gingerly (but firmly) tap the cameras bottom against a counter or other hard surface. This will often let the debris work its way out.
Let me know if this works or not.
Jul 03, 2011 | Olympus Stylus 7030 Digital Camera
Mine too mine is a kodak easyshare C330 and when i plug it it it won;t charge or turn on! please help im begging im taking it to camp in 2 weeks do i need a pro- help or is there an easy way (it uses AA...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 22, 2011 | Kodak Easyshare M753 Digital Camera
I just find it weird with the no lens problem. See after purchasing it and test was done the camera is quite okay. I've charge it for until its full and its ready for use for my trip. I'm pretty sure i did...
The island? Maybe sand got in the camera's lens holder - the cyllinder-shaped part that comes out. Or dust from the bag. Try a vacuume cleaner to take out any such thing but do not scratch the lens! Good luck
Nov 30, 2010 | Nikon Coolpix S4000 Digital Camera
Sand got in camera and lens will not stay extended keeps turning on and extending and then going back into camera.
Sounds weird but I put my mouth around the lens and gently blew into it to loosen up any sand or dirt. Then I would try to **** as hard possible to get it out. Strange, I know, and you do get some sand in your mouth, but it worked for me after a few times.
Sep 20, 2010 | Nikon Coolpix S210 Digital Camera Plum ...
Camera turns off immediately after being turned on. thought it was the battery, bought new one charged it and even though it says full charge, the camera still wont stay on.
This fault is usually caused by a lens problem.
Over 95 percent of lens problems are from Knock damaged or sand/grit in mechanism. Try turn it on in playback mode and see, does the lens come out and go back in before it turns off?
Sep 30, 2009 | Cameras
Panasonic lumix dmc-lz7 lens cover won't open
Hey how you doin.
I had the same problem during a trip around Australia, some bull dust built up around the lens area. The only thing I did to rectify the problem was to blow it out with a tyre inflator at a road house when I stopped for petrol. No problem since then.
You may have some fine sand wedged in the cover area aswel.
Good luck 'R'
Jan 26, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
I have a Cannon Powershot SD600, just got it recently and it worked great, then all of a sudden I noticed the cover lens's that slide over to protect the lens when you shut it off were messed up. Onle 1...
The Canon series are fine camera's, but they seem to suffer from lens errors (check how many people suffered from this by googling lens error canon).
The problem seems to come from sand/dust entering the body and jamming the lens gear. A handy person may be able to fix it, but I think Canon should have designed an enclosed lens gear so sand/dust can not enter.
Camera's are commonly carried in pockets, so it is logical sand and dust can be expected.
There are some issues with getting perfect focus in some situations.
Jan 03, 2009 | Canon PowerShot SD600 Digital Camera
Digital camera
Hey everardo,
What is most likely going on is that something (i.e. sand) is obstructing the movement of the lens. You can try gently blowing compressed air into the sides of the lens to try and dislodge whatever is stopping the lens movement. You can also try putting the camera on a flat surface with the lens pointing up and hold the shutter button down, and then turn the camera on. If neither of these options works I would have it cleaned by an authorized service technician. I hope this helps!
Go Ahead. Use Us.
May 29, 2008 | Cameras
Kodak EasyShare M1073 IS Digital Camera Logo
302 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
