FixYa.com
Tags:
OCZ ModStream  520-Watt Power Supply
Asus P4P800-E Deluxe Trouble
By LiZzIe - usenet poster
I recently built myself a new computer.
When I turn it on it will fail the CPU POST Test.
If I turn it off and onn a few times it will boot up.
I have tried with 3 different Power Supplies (A Delta 300 watt, A
Raildmax 420 watt and A Aspire 520 watt).
Here are my system specs-
Asus P4P800-E Deluxe Motherboard
2 512 OCZ Memory 400 mhz
P4 3.0E CPU
1 80 gig SATA drives
1 Mitsumi Floppy Drive
Lite-On 52x32x52x CD-RW drive
Lite-On 16x DVD-ROM Drive
Albatron GeForce 5700 256 MB
Is it a motherboard problem??? My 520 watt is better than my 300 watt
and has steady rails.....
Help Please
--Ian
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2005
Not Rated (0)
Charlie
Charlie - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
My son had exactly the same problem with that MB. He RMA'ed and it came back
with the same problem. A second return to be repaired, came back again,
unfixed. He gave up on ASUS and bought another brand MB. I am running an
ASUS P4S533 and have had no problems but because of his problems I will not
be buying an ASUS MB next time.
Ron
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Chandler
Chandler - usenet poster
Rating: 0%, 0 votes
Lets keep this simple, does it or does it not act flakey with the 300W PSU
you have?
  Stacey
Solution #3
Not Rated (0)
man1
man1 - usenet poster
Rating: 0%, 0 votes
<<one post snipped>>
 In ,
Ian Hopkins <linuxfanatic1 @yahoo.com> typed:
I RMA'ed my Asus (same model as listed above) about 2 months ago as it came
with dead fan headers except for the CPU. Weird, but true. No BIO solution
would 'fix' it so back it went. Made me leery of Asus at the present, so I
bought another brand. I *really* believe they are having quality control
problems, or maybe design problems with this board as there are too many
reports of problems.
...Allen
Solution #4
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
No. It does not act flakey with the 300w.
Solution #5
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rating: 0%, 0 votes
Here are the voltages for my 520 watt.
+12v 11.855
+5v 5.08
+3v 3.313
Vcore 1.36
My p4 runs of the 12v rail right?
Ill post my 300 watt voltages in a sec, i need to stick it in.
Solution #6
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
Sorry, realized that just after i posted this one. I'm aswering your
post about my PSU 's right now.
Solution #7
Not Rated (0)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
It fails the post test. The POST (Power on System Test) happens before
anything else. Nothing can happen before the POST test is passes. You
cant even display somthing on the screen. zmotherborads use
sound(on-board audio only) or LED lights built into the motherborad to
diagnose POST problems. The system works totally fine after it passes
(which happens after I switch it off and on several times).
Solution #8
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
I was talking to the other guy, his goes through post and won't load the OS,
different problem. His could be something wrong with the XP install or
trying to migrate his XP install from another machine.
You never answered my post about the PSU's, I understood you to say it boots
everytime with the 300WPSU you have but is flakey on the others?
  Stacey
Solution #9
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
  Will it boot from a floppy or a CD?
  Stacey
Solution #10
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
The fact that other people are having similar problems is making me
think that there is somthing wrong with the board. ASUS tech support
told me to take out the motherboard and check for grounding problems but
after spending several hours taking it out I still have the same
problem. They sugested I RMA the motherboard. Do you think evry ASUS
p4p800-e Deluxe will have this problem or just mine???
Solution #11
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
So you're saying it boots everytime with the 300W PSU but the others cause
this problem? I was having all sorts of flakey problems with a P4P800 which
turned out to be PSU related and that PSU is working just find in another
system with a different board. Maybe these are pickey about a certain
voltage being spot on?
  Stacey
Solution #12
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
Hi there!
I just bought a P4P800-E DX too... having a similar problem...
I can get into BIOS and everything just fine, it even recognizes my
HD
However everytime I try to boot from it, it reboots.  I've actually
left it in a continuous reboot loop for about 3 or 4 minutes... and
every time it gets JUST before the Win XP pop on Screen and *poof*
reboot...
My Specs are:
Prescott P4 2.8E GHZ CPU
Asus P4P800-E Dx motherboard
1 Stick 512MB Hynix Pc3200 RAM
MSI Nvidia FX5600 XT
1 40 Gig Samsung HD (IDE)
1 Samsung 8x4x32 CD-RW
Any help would be awesome!
Thanks!
Posted through www.HowToFixComputers.com/bb - free access to hardware troubleshooting newsgroups.
Solution #13
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
I know that that is not the case becuase when my ram is removed i get
the same problem. The POST test tests my CPU first, then RAM, Then Video
Card. It works evry time with my 300 watt. but not my 420 and 520. As i
said, my 520 is nicer than my 300 watt and has steady rails.
Solution #14
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
        In that case, Richard might well be right.  Normally clearing the CMOS
will set the speed setting for RAM (if there is one) at a more
conservative value if you have difficulty in entering CMOS for that
purpose.  You might also remove the RAM and clean the contacts either
with a pencil eraser or alcohol and try it again.  It sounds an awful
lot like your RAM is not working each time.
Solution #15
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
Memory timing issue?...change the values from SPD to Manual, alter the
timings until it's stable.
Solution #16
Not Rated (0)
Charlie
Rating: 0%, 0 votes
It fails the POST at power on and will not boot. No onscreen messages
becuase the CPU post is before the VGA post. I know its failing the PU
becuase my motherboard tell me through my speakers.
Solution #17
Not Rated (0)
Jimmy NY
Jimmy NY - usenet poster
Rating: 0%, 0 votes
        When it fails POST, does it start it at all or does it fail to start
POST??  If it starts, at what point does it fail?  Any message on screen?
Solution #18
Thanks for Trying (70)
Ranny
Ranny - usenet poster
Rating: 0%, 0 votes
Then obviously those other PSU's are causing the problem. Go buy something
like a Sparkle brand in the wattage you need and you're problem is solved.
Like I said I think these are picky about the quality of the PSU as mine was
acting just like your's is with one PSU and that PSU works fine on another
system.
  Stacey
Can you Help with these System Power Supplies problems?
my acer[3680] laptop wont...
ok. look here is the problem... Answer This...
Jeep Patriot turn signals
Hi, I just bought a 2008 jeep... Answer This...
MY SONY LAPTOP WONT BOOT
my sony laptop turns on, i see... Answer This...
electronics design
how to design unregulated power... Answer This...
Power Adaptor for 500GB LaCie...
Hi, My LaCie 500GB Porsche USB... Answer This...
Repair Service
Find System Power Sup. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
