Question about Motorola Mobility Moto Q
Moto q screen black and turns on and off
Screen fades to black and goes all haywire. only stays up if you squeeze the back
  • 1 more comment
  • suarezm124 Mar 10, 2009
    mine when i put in the battery it goes like to a gray-ish screen for a split second then turns back to a black screen i dont know what to do
  • Anonymous Mar 18, 2009
    My screen went black often, then I could fix it by pressing on it and it'd stay on for a little bit, then go black again. I could deal with that, then I fell in a creek with it in my hand, and got it to dry out. The screen wouldn't even stay on for more than a couple seconds, with the pressing thing, then it crapped out entirely. The phone works, but the screen doesn't. No warranty, no insurance. Am I screwed, or is there hope?
  • Anonymous Mar 29, 2009
    screen also goes black
    President:
  • 1,223 Answers
It is flex cable problem that is connecting LCD to module pls get it replaced the only solution may be u could be lucky and service will do it but it seems like replacement job if u dont fet the flex cable then u can easily get ur Whole LCD module along with flex cable see below link pls rate me FIXYA for help
http://cnn.cn/shop/motorola-screen-p-1529.html
Posted on Mar 19, 2009
Vizio e500ib1 50"smart tv power on light then that goes out. has 5volt stand by only, there are voltage that come up but fade out. screen is black no sound. was working great perfect picture,
Do you have voltage (3.5V) on the PSON terminal when you push the start button on the TV...if you don't its the main board that has failed
Feb 09, 2018 | Vizio Televison & Video
Motorola moto x
Tap the power button to wake it up. You may also press the volume button to wake the phone. Then you should be able to hide and show the keyboard.
Mark
Motorola Support
Sep 03, 2014 | Motorola Moto X XT1052 4G LTE 16GB...
Tv fades to black very low sound or or goes to blue & says lost siginal then goes toblank turn off set & waite a few min.& turn back on will only stay on for a few min. have to repeat.
This is not a "digital" problem that can be addressed in your setup or fixed at home. This sounds like a fading power supply. Often electronics fail slowly or partially.
You will need to consult a TV repairman.
I hope this helps!
Jun 15, 2010 | Olevia 237T 37 in. LCD TV
FP-768 (Silver, Black) (Black, Silver) 17 in. Flat Panel LCD Monitor: My screen goes haywire with all kinds of color cha...
The vertical lines/bar are sign of bad T-CON (LCD controller driver) board is bad, it is part of the LCD panel assembly, new screen will be needed, not worth it. You may try reseating the ribbon cable at the panel.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
May 16, 2010 | Fuji FP-768 17" Flat Panel LCD Monitor
My psp's screen somtimes fades out to black or
you damaged the screen i suggest seeking a repairman or send it in for repair
Oct 27, 2009 | Sony PlayStation Portable (PSP) Console
I have a rca hd56w66, my screen shuts off but the audio still stays on. For a few days, it started fading to orange and then to green and then out to black. After about a minute, the picture would come...
Sounds like you lost the power supply to guns, now this doen't mean you have to go looking for it, you will need a repair person to fix it. Word of advise, if you haven't had one of these fixed before it can range in upwards of 600.00 or more to fix now days.
Oct 09, 2009 | RCA HD56W66 56" HDTV
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Tv screen fades on and off.
i had the same problem with my last tv...turns out the solder joints on the board for the scart connector had become loose
Feb 12, 2008 | Bush WS6671 28" TV
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
153 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
