Question about Sharp AR-5316 Advanced Digital Imager Copier
L 6 letter and number appear in display L 6
  • 29 Answers
L6-00 is ussally a bad laser unit and it must be replaced, this is a 30 minute jod for a good sharp tech should cost $200-$300? not sure this copier is work that ?
Posted on Mar 09, 2009
    Scholar:
  • 136 Answers
OOOOOHHHHHH BBBBBOOOOYYYY
OOOOOOHHHHH BBBBBOOOOYYYY
You have issues with the Scanner, chances are you scanner is either not moving
OOOOOHHHH BBBBBOOOOOOYYYY call an idependant service company like ours to assist your scanner is having an error. Yep call your local Serivce Rep dealer - if your in Ct we can help
Posted on Mar 08, 2009
3 Suggested Answers
SOURCE: Letters and numbers appear in the display
F2 appears on sharp AR-M205 copier
Posted on Apr 05, 2008
  • 87 Answers
L6 SHOWS LASER PROBLEM MOTOR MAY BI SENSOR.AND L4 DRIVE PROBLEM MAIN MOTOR OR MAY BI ANY GEAR IN DRIVE.CHECK ALL GEARS .DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Posted on Feb 22, 2009
FF appears on the display and treadmill will not operate
please follow this steps and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 03, 2013 | Proform 695 LT Treadmill
Fitstride t920 treadmill faults
Reset the machine follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
· 2
· 3
Oct 07, 2013 | Exercise & Fitness
Frigidaire front loading washer, letter J in the display, will not operate.
First I recommend unplugging the washer for a couple of minutes then turning it back on. If that doesn't clear it unfortunately your are going to have to replace the control board. You can find the part here
http://www.repairclinic.com/ Just use your model number to look it up.
Oct 27, 2012 | Frigidaire Washing Machines
My Electronic crossword puzzles by RadioShack comes on but will not do anything. I just put in new batteries. I do not have my manual.
Adjusting The Display
To increase or decrease the display's contrast so it is easier to read,
hold down FUNCTION, then press /\ or \/ on the cursor pad.
Playing The Game
1. Press ON/OFF to turn on the game.
If you have not worked a puzzle since installing or replacing the
batteries, CROSSWORD MASTER appears. Otherwise, the display is as it
was when the game was turned off.
2. To start a new puzzle at any time, press FUNCTION and 1 (I), 2 (O), or
3 (P) at the same time. 1 is for beginner-type games, and 2 and 3
increase in difficulty. NEW GAME LEVEL 1, 2, OR 3 Y/N appears.
3. Press Y to start a new puzzle. A crossword grid with flashing cursor
appears (O).
Otherwise, press N. The display appears as it was when you pressed
FUNCTION and 1, 2, or 3.
4. Press (or hold down) /\, \/, <, or > on the cursor pad to move the
cursor around the puzzle.
5. With the flashing cursor in the desired location, press ? to see the
clue(s) for the word(s) in that location.
Any letters you already entered appear, along with a dash for each
missing letter. The number of letters appears in parentheses - for
example, (5) for a solution with 5 letters. If the solution includes
more than one word, the number of letters for each word appears in the
format - for example, (5, 3, 4) for a solution with three words.
If the flashing cursor appears at the junction of two words (across
and down), both clues appear, across first, then down.
6. Press ? again to return to the crossword display, then use the letter
keys to type your answer.
If the flashing cursor was at the junction of two words and you enter
the first letter of your answer, two small arrows appear in the
adjacent across and down squares. Before typing the rest of your
answer, press > or \/ (across or down) on the cursor pad to indicate
which word you are entering.
Press /\ on the keyboard to erase the letter just above, and < to
erase the letter to the left of, the flashing cursor.
To erase a word, hold down FUNCTION and press WORD DELETE (Z).
To spell check the puzzle at any time, hold down FUNCTION and press
SPELL (T). The [+] symbol indicates the location of each incorrect
letter.
When you complete a crossword correctly, GAME COMPLETED appears.
7. Press ON/OFF to turn off the game. The current puzzle is saved.
(EB 12/08/98)
Privacy Policy
Mar 30, 2011 | Computers & Internet
I need to program are fax machine to have are fax # on documents that are being sent to other fax machine's
1. Press <function> then "Down Arrow" on the <start> button until [ENTRY MODE] appears.
2. Press "Right Arrow" on the <start> button until [OWN NUMBER SET] is displayed.
3. Press "Right Arrow" [ENTER FAX #] will display.
4. Enter your fax number with the number keys (max. 20 digits). To insert space, press <#>, to enter "+" press <*>. To clear a mistake press <speaker> button.
5. Press <start/memory> button.
6. Enter your name by pressing number keys for each letter. Will display the capital letter for each of 3-4 letters to number, then number, then the lower case letters for each press. Use "Right Arrow" to go to next letter, if using the same number key (IE: B to A uses 1, use "right arrow" to go to next space). The #1 will give a space between words. (Max. 24 Characters).
7. Press <start/memory> [DATE&TIME SET] will display.
8. Press <stop> to exit.
Mar 19, 2010 | Sharp UX-B750 Inkjet Fax
Problem with entering anti-theft radio code for Honda Fit: The radio screen says: "Enter Code:" I enter the confirmed correct code, but when doing so when the actual code (all numbers) turn into letters or...
when you use the "preset keys" (the keys on the radio with numbers on them) to enter the code, each time you press a code number, a letter appears [c, o, d, e]. once the word is spelled out, from entering the correct 5 digits, the radio is reset, ready to go.
BUT if you miss a number, enter a wrong number, whatever, each number pressed, still makes a letter appear from the word "code". once the word is spelled out, by entering ANY 5 numbers, if ANY of the 5 is wrong, the radio displays a message "Error" and then a number 1 thru 10.
When you see the word "Error..."
the next preset button you push, starts the whole thing over again. The radio says "Enter code". That is when you enter the 1st of the 5 digits, the letter C appears, enter the next digit, the letter O appears, enter the next digit, the letter D appears, enter the last digit, the letter E apperas, the radio is reset, ready to go, if you got the 5 correct numbers entered.
you have 10 chances to enter the right 5 digit code. Each wrong try of 5 digits yeilds a display of "Error 1", "Error 2", "Error 3", etc 'till you get to 10 incorrect tries of 5 digits each.
If you dont get it right in 10 tries, you have to leave the radio "on" for an hour, then it will let you start the 10 tries over again.
Apr 26, 2009 | 2007 Honda Fit Sport Hatchback
Feb 19, 2009 | Sharp AR-5320 Black and White Copier
I want to clean LED letters or numbers
either there is a small leakage of current in the display panel or there might be a shortage of supply.in either cases the display looks faulty.try to check the leakage by removing the panel.better be done by a professional.try contacting any technician available.sometimes the problem solves by just switching on and off the machine a couple of times.
Dec 13, 2008 | Kenmore Elite 45986 Front Load Washer
I really need to get my CD case out to make sure the code is the polygon motor, not a good sign, could need a new laser assbly.
Jan 23, 2008 | Sharp AR-M205 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
75 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
