Question about Toshiba Satellite A60 Notebook
Dismantle toshiba motherborad but bios lock problem still exist?
Pls see my dismantled motherboard photo from http://www.mygrace.com.tw/toshibasatilltem30.JPG
any ideal or suggestion ?
  • yuna_hsu Mar 18, 2009
    do I need to find a connector is USB to 25 pin male D sub for my satillite m30 laptop USB print port ? Then I can made this dongle....
  • Toshiba Master
  • 32,281 Answers
Are you trying to remove the BIOS password on your Toshiba?
If so try this :-
You need to build a hardware device that plugs into the printer port.
Get a 25 pin male D sub connector, and solder various wires
to the pins numbered below. The pins on the connector are numbered 1 to 25
For a picture of this hardware device (dongle) go to :-
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg
Connect these pins together by soldering thin insulated wires to the following pins :-
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the dongle in the printer port and boot up the laptop, you will then be able to bypass the BIOS password and go into the BIOS to reset/remove the password.
Posted on Mar 08, 2009
  • Chris Hingee
    Chris Hingee Mar 18, 2009
    It only works on Toshiba laptops with a LPT1 (25 pin DSub connector) printer port.
I can no longer access my bios through the supervisor password, therefore I can no longer activate boot priority. I need to repair a windows 10 continuous loop that resulted from an update gone wrong!
The password that was set is a security device and there is no back door. Options are; replace the BIOS chip with a known good programmed chip, replace the motherboard or remember the password.
Oct 01, 2016 | Computers & Internet
How do I remove the doorknob to possibly oil it?
it would depend on the door knob construction and what was stiff inside it.
The problem could be part of the handle or part of the lock mechanism.
For a typical indoor door lever handle, undo the screws on the face plate and take the handle off and oil as appropriate. You may have oil handles on both sides of the door.
For a rotating door knob handle there is generally a single screw on the underside of the knob
For a lock mechanism, you could just spray oil inside the mortise moving part (you wouldn't have to dismantle anything to do this!).
However to dismantle it, you'll need to remove handles on both sides of the door, remove the square bar that slots between both handles and remove the lock mechanism (you may have to remove locating screws that exist on the mortise face. If lock mechanism is user serviceable then there will be screws to undo to allow it to be dismantled. If none exist then it is probably worth buying a new one.
Oct 16, 2014 | Hardware & Accessories
Toshiba satelitte 855
do bypass or reset hdd/sdd password without knowing it and its locked presently?
Jan 27, 2013 | Toshiba Satellite Computers & Internet
Toshiba Satellite L305-S5894 (PSLB8U-023003 Motherborad Driver
Motherboards don't have a driver per say. They do have something called a BIOS.
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the BIOS drivers. This is called Flashing the BIOS
Apr 19, 2012 | Toshiba Satellite L305-S5894...
The power supply light and battery charge light is on but the laptop will not boot and there is On/Off light. It may be the lid switch. I cannot find this switch.
Not quite sure what you mean by "On/Off light" but I'm assuming you mean the laptop appears to switch on.
This problem sounds like it's an issue with either the bios or the cpu. It's a fairly common problem for the bios to go "bad", possibly through a bad bios flash, needing either a clear of the cmos, or reflashing (more likely a new bios chip.
The cpu issue is rather more unlikely unless the laptop has been dismantled and the cpu socket unlocked.
Solutions to this problem require dismantling of the laptop, so unless you know what you're doing, I'd recommend taking it to a repair centre.
Feb 09, 2011 | Toshiba Satellite A215-S4747 Notebook
My computer is locked in the BIOS Setting
I assume you have already tried the Dell site & searched (using eg google) for 'Inspiron 8600 BIOS reset' so I'll not bother repeating your efforts.
Since you posted here, I can only assume you have been unable to find any information about special power-on key combinations or any small holes underneath (where a paperclip can be used to reset the BIOS) ... in which case your only option is to dismantle the laptop, locate the BIOS battery and remove it for 30 seconds or so.
To find out how to dismantle the laptop, search (google) for 'Inspiron 8600 BIOS Battery replacement' ....
Mar 17, 2009 | Dell Inspiron 8600 Notebook
Default phoenixbios pasword
If you've lost the bios password, you'll probably have to 'flash' the bios. If you feel comfortable enough, you can dismantle the laptop and remove the motherboard battery for several minutes, then replace it and reassemble the system, see if the password has been cleared. (Note: The motherboard battery is NOT the laptop battery; you have to remove both!)
Feb 13, 2009 | Toshiba Satellite A135-S2276 Notebook
Bios locked
try to remove the CMOS battery from the motherboard and re insert again..
Jan 17, 2009 | IBM ThinkPad T23 2647 Notebook
I have a toshiba L300 laptop with vista....i re installed that to XP...after that i download bios update (previous version insyde 1.3 v now 1.5v)from toshiba and installed....the setup was successfull......
I solved that problem with unpluging every kind of connectors (Usb..) Shuting completly down. Unplug the powersupply and restart the whole system. After that, go to BIOS and see the SATA Option, set to compatible and not ASHC(or whatever its called). After the BIOS Update some of my BIOS settings were changed.
Dec 07, 2008 | Intel D845GEBV2 Motherboard
Unexpected shut down
First, you need to find out what is causing the shutdown problem.
Most likely since you have this laptop for 3years now and (i am assuming you havent had this serviced). You might be suffering from overheat problems since you are using a DESKTOP P4 cpu.
Try to dismantle your laptop and remove the Fan and Heat sink. CLEAN them and put new thermal paste to the cpu.
Do that and see if this fixes the problem. If not, let me know again
If i was able to help please rate this solution as a fixya!
thanks
Apr 11, 2008 | Toshiba Satellite A75-S231 Notebook
Toshiba Satellite A60 Notebook Logo
343 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
