Question about Nikon Coolpix L11 Digital Camera
Will not turn on the green light only turns on for
Camera will not turn on, the green light only turns on for a second and turns off. I've put a few new batteries and it still does the same thing.
  • 1 more comment
  • Anonymous Apr 10, 2009
    I had the same problem. Sent the camera in for repair and it lasted a few more months. This is a really bad camera and I'm about to toss it in the trash!
  • Pauly-Dee Apr 11, 2009
    My Ccard just stopped being read by camera.  Now camera will not turn on at all with very new batteries.  Is there a way to manually reste camera?  The card had worked for a year in the camera.  HELP!!!!????!!!!
  • Anonymous Apr 14, 2009
    darn camera has the same problem - i replace the batteries and the camera turns on for about half a second and then shuts down.
  • Nikon Master
  • 32,281 Answers
To reset the camera, remove the batteries and leave them out for approx. 1 hour then replace the batteries. See if the camers works again.
Posted on Mar 08, 2009
5 Suggested Answers
leepania
  • 1099 Answers
SOURCE: When I turn my camera on it stays on for a few
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Posted on Jan 14, 2010
mcomijohns
  • 477 Answers
SOURCE: Wont Turn on at all - Casio Ex-z750
Contact the person @ www.digitalcamrepair.com he can repair it for you.
Posted on Jun 12, 2008
silly girl
  • 513 Answers
SOURCE: olympus sp 350
Are you sure you finalized the firmware upgrade procedure according to the instructions? This sounds a little like you pulled the plug a little too soon... Have you done it according to these instructions: http://www.olympusamerica.com/cpg_section/OMfirm.asp And kept the camera connected until the update was 100 % complete? If you did everything right, try reseting the camera - take the batteries out for the day, and see if it helps. if you're back to step one(the reason you did the upgrade), try the firmware upgrade again. If still it doesn't work contact olympus, and I hope you have a valid warranty. Good luck
Posted on Jun 25, 2006
SOURCE: My camera won't turn on even with new batteries
Just figured out a solution. When turning on camera, press the review button (probably any'll work but this is the one I used) as the kodak screen appears. My camera still won't turn on normally but this is better then no camera at all! Good luck and hope this helps.
Posted on Apr 01, 2008
When I put my printer on, both the red 'on' light and the 'green' problem light are flashing intermittetly . I have tried to reset the printer by pressing the 'green light' down for a few seconds..but...
when I put my printer on, both the red \'on\' light and the \'green\' problem light are flashing intermittetly . I have tried to reset the printer by pressing the \'green light\' down for a few seconds..but nothing now happens on this mode. I have also turned the printer off and back on again, and lastly took the power cable off and back on again..and still no joy..any ideas
Nov 02, 2010 | Epson Stylus C46 InkJet Printer
When i turn on my tv the light turns orange green for a few seconds and then turns red and flash's... What do i do?
Jun 18, 2010 | Thomson LCDB 03B 27 in. Television
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
Lense not closing, switching on for one second then shuts down. when attempting to turn on green light flashes then turns off
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 21, 2008 | Canon Cameras
Samsung camera not turning on.
First make sure you batteries are strong.
Then this is not a great solution, but try this. 1) Remove the battery. 2) Hold down the power button and wait 30 seconds...but keep holding the button. 3) After 30 seconds and while holding the button down insert the batteries and then close the compartment. It should come on.
I managed to duplicate the problem by opening the battery compartment with the camera turn on and then if I put them back it would turn on and the lense does not retract.
Good Luck
Dec 25, 2007 | Samsung Digimax D53 Digital Camera
Won't turn on
Ouch! You can't use an AC adapter with any battery-operated equipment you choose to just because the plug fits physically. The A70 requires 5-6 volts, and a Pavilion adapter typically puts out 18 volts. You most probably blew out your Canon's power supply within a few seconds, unless it's fused somehow. Next stop: tech support/repair shop/camera cemetery. Sorry.
Aug 23, 2006 | Canon PowerShot A70 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
460 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
