Question about Archos Jukebox Studio 20 MP3 Player
Hard drive error
I haven't used my device much since purchasing it new. It is never been dropped. Recently I turned it on to play and after playing 3 or 4 songs normally the screen displayed "Hard disk error". Then the device would not play any more music and a knocking sound started. Am I totally out of luck? Or, is there anything to be done to remedy this?
  • thebagelboy May 16, 2009
    I have same problem. Hard drive error. I don' t want to lose my 1000 songs I have on device.any other ideas.
Same exact problem let sit for several months went to turn on and all i could see was a "hard disk error" message flash very quickly and then turn off. after months of no help online i decided to open
my jukebox 20 and there are 4 ni-cad batteries inside. i removed batteries and replaced with 4 "AA"
regular energizer batteries and it works fine. at least until i extract my 1000 songs and put them on another device so i ll never lose them. GOOD LUCK.
Posted on May 25, 2009
Firmare upgrade on the Archos site should solve this. I had the same problem, updated and unit was fine only problem is you will lose all your files
Posted on Mar 08, 2009
HOW DO I USE THE USB PORT TO PLAY MOVIES
Tom,
To be able to play movies stored on a USB device (it doesn´t matter if it's a usb pen, a usb hard drive, etc), you will need two things:
1.- The device where you want to play the movies must support the USB device that you're using (not all USBs are the same, and they can be formatted differently, too). So if when you plug it in, the TV doesn´t recognize it, use a different USB device.
2.- The movies that you put on the USB device must be palyable by your device. ie: your TV, BluRay, etc must be able to decode and play the movie format, and this can be AVI, DIVX, XVID, H624, QT, MKV, etc. Even if your device reproduces DIVX movies, if the movie is encoded in a weird format, it won't be playable. The fastest way to know is trial and error.
Feb 09, 2015 | Hard Computers & Internet
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
When i plug in the usb to my computer it is not recognized and does not show anywher
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
b>
Dec 14, 2012 | SimpleTech 500GB SimpleDrive Pro External...
Won't recognize external hd
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
I have error code 80010514. i have tried rewritting currupt files and eracing the hard drive. this had no effect. my ps3 will not play most of the games that i own. we recently tried to clean her out. this...
It sounds like the laser in your blu-ray drive is dead. You will need to purchase a replacement diode ( or drive ) and replace it yourself, this usually costs around $70. Or, you can pay $150 and Sony will replace it for you.
Mar 20, 2011 | Sony Playstation 3 (PS3) Console
How do I down load to an external drive and not the main computer
1. First, you need to select the external drive while saving any game.
2. Try to play it from External drive first, if game does not play from external drive then try to play it from the Internal drive.
3. It does not make any difference whether you are playing game from external or interna drive because both the drives will use the computer resources and softwares to play the games.
Good Luck.
Mar 23, 2010 | Computers & Internet
My 360 only plays cds or dvd s wont play games please advise
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
Feb 15, 2010 | Microsoft Xbox 360 Console
Can you play PS2 games on a PS3?
If you bought the original PS3 when it first came out and purchased the expensive one with the larger hard drive, it will be able to play *some* PS2 games. If you bought the cheaper one with the smaller hard drive or purchased your PS3 once the prices started dropping, it will have no capabilities of playing PS2 games, as Sony has decided to not continue making the system semi-backwards-compatible.
Oct 31, 2009 | Sony Playstation 3 (PS3) Console
PSP cannot turn on
i think youll need to call to get service done............if your psp warranty isnt up they may give you a new psp
Aug 03, 2009 | Sony PlayStation Portable (PSP) Console
For some reason i can play sierra 117. also the catch skull is mi
This sounds similar to what happened to me, except I couldn't load some multiplayer maps.
If you know someone that recently bought Halo 3,(within a week) ask him/her to return it with your defective game in the case. He/she will receive a new unopened Halo 3, and you can take your friend's recently opened copy of Halo 3.
If you don't want to be cheapskate, you can borrow Halo 3 from a friend, and save it on your hard drive. After that, you can use your defective disc just to play the game. Unfortunately, if you save it on your hard drive, it supposedly makes the game slower when searching for multiplayer matches online, and other things.
If you don't care about saving money, you could buy another copy of Halo 3.
Jul 14, 2009 | Microsoft Xbox 360 Console
Archos Jukebox Studio 20 MP3 Player Logo
300 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
