Unable to boot win xp cd. not detected by compaq presario 5000 series interneal cd rom LTN 403 DQ24
  • NARESH KHERA Mar 08, 2009
    the driver for cd rom is loaded & bios option has cd boot as no. 1.
    at times cd rom detects the cd & at other times it does not.
  • NARESH KHERA Mar 09, 2009
    I use the boot cd for repair.
    How to load the deiver before boot.
    Scholar:
  • 124 Answers
Drive requires cd drivers to run Boot CD.
Some versions came with floppy disk to start cdrom drives, This will also require a floppy drive.
You may also try hitting f10 to enter bios setup make sure cdrom is bootable.
Posted on Mar 08, 2009
  • Mark Van Skiver Mar 08, 2009
    Typical.
    1. Check that your cd is not scratched or has finger or smudge prints. If scratched you can take to music cd shop &have them buff out scratches for a fee of course. If smudged clean with clean cloth & 99% isporiL alchol.
    2. Sometimes the cd drivers remain loaded in memory after restart other times there dumped & cannot read cd. You can run driver before start up of windows to allow access to cdrrom but it uses up memory & causes conflict when windows starts.
    How often do you run xp boot? should only need if system failure.
My compaq presario f768wm isnt recognizing my cd/dvd rom. my camera quit working and also it says it can't find my audio output device.
For that problem, Try first replace that internal DVD-rom drive other good internal DVD-rom drive. if not Also Detected or recognize.
Try this second solution. insert external USB type DVD-ROM. if not recognize also, Your operating system Have internal software device data corrupted. You need to reinstall operating System like windows xp, windows 7 (OS) etc.. to fix data Corrupted of operating system device for hardware software.
Please see sample external DVD-rom USB type.
Just let me know if not yet working your Compaq Presario 700 series DVD-rom Drive.
Thanks for using Fixya.
Aug 19, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Trying to reinstall windows XP on Dell Dimension 8300....cant' start up using the CD drive...
Inpect the computers preexisting operating systems to ascertain compartibility to windows XP. Only XP computers would recognise XP operatign systems. Attemptign to install windows XP onto alternate system either windows 98, 2000, mellanuim or Vista XP or 7 is least achieveable unless the old system were erased or new empty storage disk drive were acquired and replaced.
Feb 03, 2011 | Compaq Presario 5000 PC Desktop
I have an old Presario 5000 series PC, hard disk crashed, bought a new hard disk and tried to use the Quick Restore CD's to Restore to Factory settings. Can't seem to boot up from Disc 1 of the Quick...
For boot from disk first you have to set first boot device option in BIOS.
for that when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot menu then set first boot device as your cd/dvd rom.
then save settings then insert recovery diks in rom then check.
Then it boot from disk if your disk and cd.dvd rom works fine.
Let me know if you need more assistance.
Thanks.
Nov 05, 2009 | Compaq Presario 5000 PC Desktop
Problem with compaq presario 2500
hi
go to the Bios setup and set the first booting device as CD drive and it will check the CD first
cheers
pls rate if it was any help
Jul 05, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
Compaq 2500
The disk itself may be corrupt , go to microsoft and download xp home or pro , whatever your using and burn to a disk .If you don't have access to another computer , go to a repair shop and you can usually buy a burn't copy of xp for 5 to 10 dollars . RE-install as usual. please note !!! you must know what service pack is needed for the install . SP1 - SP2 ....OR to be on the safe side just get XP SP1. good luck!
May 30, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
Insataling windows xp problms
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
Help!!
Is it a restart with a blue screen? Is it XP?
If it is XP do the following:
Boot the laptop with a Win XP cd.
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | HP Compaq Presario V2000 Notebook
Tried to upgrade my hp from windows 98 to xp now it wont come on. It beeps then the monitor goes to sleep.Can not even run my redtore disc.
At start up of computer start tapping the f-2 key until you open the bios.In the bios change your drive order so that the computer boots first to CD-rom.
Mar 18, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
370 people viewed this question
David Payne
David Payne
