Question about Alpine MRV-1507 Car Audio Amplifier
My amps keep turning off
Have 2 JL audio mono block 500/1 amps hooked up to 2 JL12v2W6's an a 1.6 farad lanzar cap with 0ga running from the battery to the cap an to the distrubution block then 4 ga to my amps. then the grounds from the amps and i the cap to a smaller distrabution block an to the body of the car.. it powers up 4 about a min then both amps shut down but i test them an they have power but dont run the amps. then i take the fuses out then put them back in an they turn back on. then shut off whats the deal should i ground them all seprately?
  • 3 Answers
That is possible,but you might need to run an another battery so they can get the suffenent power and you will need a bigger alternater
Posted on Mar 11, 2009
I hooked up my jl audio 500/1 and it turns on but there is no response from the subs.
-Did you verify that you have an input signal?
-Is the amp going into protection?
-If they are bridged mono, are they bridged across the appropriate terminals?
-If there is a subwoofer line out on your head unit is it muted or turned off?
Jan 04, 2010 | Jl Audio 500/1 Car Audio Amplifier
My amp cuts off when i turn it up
do you have the amp knobs cranked?? gain and freq
May 05, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
If I buy 2 12 inch jl audio w7 subs would it be better to get 1 or 2 jl audio 1000 watt amps
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
Oct 30, 2008 | Jl Audio Car Audio & Video
Jl audio
If the amp was hot, it probably has a serious problem. You should have it checked out by a qualified tech. Don't continue to use it. More serious damage could occur.
May 29, 2008 | Jl Audio 1000/1 Car Audio Amplifier
2.0 Farad Capacitor
The answer is yes, any amount of amplifiers can be hooked up to a cap. Obviously the more amps you hook up to it the less you are going to nodice the difference with the same amout of farads. The only thing that I am worried about is the wiring from your battery to your cap. As long as you have a decent gauge wire running back you should have no problem. And for this instance I would recommend 0 guage, you might be able to get away with 4 but I would highly recommend 0. Over all I would recommend 0 guage on all installs unless you are going small and don't plan on upgrading. I hope I could help
-Andrew Hawkins
Apr 23, 2008 | Car Audio & Video
Lanzar viberant 5.0 farad cap
Both "+" connections on the cap are tied together within the cap, as are both "-" connections. Lanzar provides two sets to allow the cap to be more easily shared between the power/ground lines of two amplifiers. If you have only one amp, connecting to one or both of the +/- sets should not matter (although connecting to both +/- sets might reduce the resistance between the cap and the power wiring of your amp).
Feb 16, 2008 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Hok up amp and all fuses blow on distribution block
somehow, DC car voltage has gotten to the speaker outputs of your amp! your fuses are saving your speakers from meltdown. your amp has melted down. toss it after checking with ohmeter as follows: disconnect amp completely. red wire from ohmmeter to +12Vin. black wire to SPK+. if ohms are anything below 1000 ohms, then toss it. An electrical short is equivalent to flooding your entire house with a leaky faucet. No telling what that rapid current will encounter along the amplifier section. you could get lucky and find all power MOSFETS have shorted and replace them. good luck.
May 31, 2007 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
152 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
