Do you have a "delay" button? Press that, a yellow LED should light, and you then set the start time. The manuals are all online, you know...derrrrrrrp!
If the timer does not keep the time of day then it is faulty and needs to be replaced. Timers have adjustable tabs to turn the timer on and off at a set times of day.
That timer is not identified: Copy following link to see variety of timers that might match your timer, and then download same-similar manual: http://waterheatertimer.org/Woods-timers-and-manuals.html
Copy following link for possible photo assistance of tripper installation: http://waterheatertimer.org/images/WH-lever-005-500.jpg http://waterheatertimer.org/Intermatic-timers-and-manulas.html#pool
1) If you have zilla digital power strip, there is no reset button. It appears you can reset timer by removing small battery located on back of timer. Battery serves as a back-up for timer settings, and display will not show without battery. Most battery-operated timers that do not have reset button are reset by removing battery.
Some battery operated timers retain programming forever even if battery is removed for months, and then programming is still there when new battery is installed. However this type of timer has a reset button, but zilla does not.
2) A second way to clear programming is to press PRG button to review each program, and set each program to another time. I don't know if this will work since you can't 'zero' out the settings.
I'm not sure what timer you have. Programmable timers are made so you press-and-hold the button, and then display goes up through the numbers as you describe. I test timers, and have not seen the fault you describe. 4-6% of timers arrive defective. However you have several timers that do the same thing. If you press the button once, then the first number shows, press button again and next number shows.
If your timer is going up through the number with one push of the button then try resetting timer. I cannot identify your timer to know what the reset steps are.
Also, many timers you push the + button to go up through the numbers, and push the - button to go down through the numbers > try both buttons since one may be made for individual selection and other for acceleration through all numbers. If timer operates on 120V, perform circuit analyzer test on the circuit to eliminate electrical as source of problem. If this is a hard-wire timer, carefully review of wiring.
If you find the specific source of problem, add a comment.
