Question about NeoWave PC Audio Graphic Equalizer External Sound System
Loss of volume control
The volume control was uninstalled, how can i put it back but my laptop doesnt have a cd-rom waithot buying an external cd-rom
  • 86 Answers
To use another pc and insert volume control cd , then the driver copy to a pen drive and peste it . then you can insert pen drive in your laptop and install the driver.
JEMS 4 U''''''''''''''''
Posted on Mar 08, 2009
My little sisters dell inspiron mini just got the Unmountable boot volume message. I've looked online but most of the options require a cd which is of course not helpful when the mini doesn't have...
The best option is, look around for external cd-rom with usb connection, and reformat the laptop.You need to go into the bios and change the boot order to make your usb cd-rom to first in the boot list. Once the usb cd-rom is plugged into used port, with operation system cd in it, on your laptop..press F2..go into the bios, to the boot order make your usb cd-rom on top boot list,,then save changes to exit the bios. Once again the system reboots..with message PRESS ANY KEY TO BOOT FROM CD ROM.. so just simple steps to follow..its not going to be expensive..good luck
Sep 17, 2011 | Dell Inspiron Mini 10 Notebook
Hi i have an l300 my main problem is with the CD /DVD Rom it doesnt read any CDs the light turns on and there is a sound go on for 10-15 seconds and nothing happens. Knowing that i didnt use the rom...
The ROM drive is faulty you can either use an external one for the time being or buy a new internal laptop rom drive making use you buy the correct one.
Jun 27, 2011 | Computers & Internet
Hello i want buy solution cd-rom driver..... my
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties you will have options under general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Jan 16, 2011 | Dell (074JH) Internal 48x CD-ROM Drive
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
My CD Drive is no longer working it says code 39. I also tried my external DVD drive it says code 39 as well. How do I fix this?
hope this helps
Oct 21, 2010 | Compaq (120192-B21) CD-ROM Drive
Driver doesnt read disks or even work
try this  go to the device manager click on the DVD/CD rom drives and right click the options and then click uninstall
Now right click on the DVD/CD rom drives and then click scan for hardware changes
now open the cd tray and put and dvd.
Jun 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
Assus external cd/dvd rom
Hl
You must buy asus external drive its worth
Harry
Oct 31, 2008 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Cd-dvd rom error code 10. failed to start
I had similar problems with my HP computer and i found either uninstall it through device manager the reinstalling it through new hardware wizaed in control panel. Or if that doesnt work try opening your laptop up and unplugging/removing the drive itself and restarting the laptop then turn it off again and put the drive back in the computer should then register it as a new device and reinstall it. that second option worked for my drive so it should hopefully work for yours
God Bless
Braydon
Mar 28, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Windows XP Unsuccessful on Start Up
no you just need to fix your bios problem, if you dont have the manual take the battery out of the motherboard that keeps power to the bios keep it out for a few minutes put it back in then turn it on it should go to bios automatically then just go to set best defaults for ststem hit y for yes then hit enter and it should take off fine if it dont then you need to take it to a pro who can reset it for you manually or reprogram it that would be cheapest for you without trashing it.
Dec 30, 2007 | Acer Aspire 3000 Notebook
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
NeoWave PC Audio Graphic Equalizer External Sound System Logo
43 people viewed this question
Top NeoWave Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a NeoWave Computer and Internet Expert? Answer questions, earn points and help others
