Question about Miele Blue Moon Bagged Canister Vacuum
Won't turn on, red triangular warning light turns on. It worked a few days ago and now nothing happens when I press the button to turn the motor on. I have a Meile Champagne canister vaccum that won't run.
  • jaydo0690 Mar 12, 2009
    when i turn it on the green light comes on then the red attention light comes on and nothing happends i have changed all the filters and it has recently come back from the shop
  • Anonymous May 07, 2009
    red triangular warning light on.
    nothing happens when i press the start button.
  • 134 Answers
Hi
The bad news is 99.9% the motor is gone
Posted on Mar 08, 2009
Why won't my Roomba start when I press a green "clean" button?
Bad PC board. Throw it away. Robot vacs are nothing more than novelties ( expensive toys ) They may do what you want them to do at first but they never last very long and other than brush replacements they are not repairable. If it is within the warranty period you can get a replacement with that.
Jul 01, 2017 | Roomba iRobot 630 Vacuum Cleaning Robot
I have a days on dc28. It all of a sudden will not turn on. No blinking light, nothing. This happened a few years ago and we had to have it repaired. Can I fix myself?
Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting....
Dec 23, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
Vacuum turns itself off after 5 minutes of operating. The hose had a little matter in it, but wasn't clogged, and the filter indicator is green. It was cleaning the carpet just fine before it stopped, the...
The motor may have a thermal protect feature built in. Opens circuit when too hot. This is to protect motor and to prevent a fire. If you can check for lint build up around motor. Also, motor could be on it's way out.
Sep 28, 2013 | Hoover UH70120 WindTunnel TSeries Rewind...
The red filter light will not reset after replacing the filter on my Miele S5980
Hi There, I actually did a repair on this problem only a couple of weeks ago. The problem could be that the small lever that pushes on the reset button on the circuit board is bent or broken. The little button costs about $10 from memory and certainly a whole lot cheaper than the board itself which is $234. Just to clarify in my case there was nothing wrong with the board, I was able to manually push the reset switch on the board and replace the tiny lever and problem was solved.
Apr 17, 2013 | Miele S5980 Capricorn /SEB 217
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Miele brush bar not spinning
Either the touchpad is defective, or the motor is bad.
May 11, 2012 | Miele Vacuums
Will not start, will not reset
I have a Silver Moon S558, when I turn it on the power light comes on and a few secords later the red warning light comes on. What is causing the vacuum not to work? One day I was vacuuming, turned it off and a few minutes later went to turn it on and nothing, but these lights turning on. Is there a fix?
Mar 11, 2011 | Miele s558 Silver Moon Vacuum
Help
Same thing happened to me, I called the company, and they told me to remove the battery, press the on button for 5 seconds, which clears the system, replace the battery and do a long charge 12 hours. I'm in the process of doing that now.
Dec 14, 2007 | iRobot Roomba Red 4100 Bagless Robotic...
Miele Blue Moon Bagged Canister Vacuum Logo
773 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
