Question about EliteGroup P4VMM2 Motherboard
I can not remember where wires go
I can not remember where to put the power led power switch reset switch H.D.D. led and the turbo led wires go
can anyone please help
  • 2 more comments
  • Anonymous Mar 08, 2009
    i believe it is something like this:
    P4VMM2 V3.2A P4/FSB 533/VIA/SDRM+DDR/A&V&L/MATX Motherboard?
  • loriwayne Mar 08, 2009
    no it is not sorry i thought it was but it isnt
  • Manoj Misal
    Manoj Misal May 11, 2010
    need more info.
    1. motherboard make
  • Anonymous Mar 19, 2014
    Power switch and reset wires
    Problem Solver:
  • 17 Answers
All the configuration should be printed on yur motherboard....maybe.....?
Posted on Mar 08, 2009
Need pic of power hook up to mother board
How about the motherboard manual instead?
http://support.asus.com/Download.aspx?SLanguage=en&m=P4P800+SE&p=1&os=
To the right of the - Select OS - box, click on the blue Down Arrow.
Click on WinXP
(Doesn't matter which Operating System is chosen, we're just going after the motherboard manual)
Scroll down, click on the + sign to the left of Manual (10)
Scroll down, go to the 4th file down -
Version E1886
P4P800 SE User's Manual English Version E1886
Right underneath this file name click on the Blue - Global
Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on Global, it may take up to 30 seconds before the first page comes up.
At the Top of the Adobe Reader is the page number box. It is to the right of Page: and the Down Arrow.
You can go page by page to arrive at the page you want, or if you know the page you want; perform this,
1) Put your mouse cursor in the page number box, to the Right of 1
Left-click once. Now backspace the 1 out.
2) Type the page number you want.
3) Press the Enter key
Go to Page 25 - 2.2.3 Motherboard Layout
[Use the Zoom Out icon at top ( - ) by clicking on it, to decrease the view size.
Use the Zoom In icon ( + ) to increase the view size ]
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel connect to; is the Front Panel header.
Goes by many abbreviations.
Here we see it is PANEL_1
Two rows of 10 contact pins.
Now go to Page 55 - 12. System Panel Connector
I see no numbering system is used, so I will number the pins.
The Top row is numbered EVEN.
The Bottom row is numbered ODD.
Starting on the Top row, going from LEFT to RIGHT,
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20.
Starting on the Bottom row, going from Left to Right,
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pin 5 is N/C. Not Connected. Don't even know if the pin is there, or just a blank spot. (But you will)
C) Pins 7 and 9 are for a SMI lead.
"System Management Interrupt Lead (2 pin SMI)
The 2-pin connector permits switching to suspend mode, or "GREEN" mode, in which system activity is instantly decreased to save power and to expand the life of certain system components. Attach the case-mounted suspend switch to this 2-pin connector."
Suggest leave alone.
D) Pins 11 and 13 are for the Power On switch.
E) Pin 15 is N/C. (Or again, may not be there)
F) Pins 17 and 19 are for a Reset switch, IF a Reset switch is used.
G) Pins 2, 4, and 6 are for a Power On LED. (Light)
A 3-wire Power On LED.
Pin 2 is for a Positive ( + ) wire.
Pin 4 is for a Positive ( + ) wire
Pin 6 is for a Negative ( - ) wire.
This is for a Power On LED that is Dual Color.
Used back in the day when there was Turbo Mode, and Normal Mode.
A farce in reality.
Turbo Mode WAS the normal mode, while Normal Mode was a lesser version.
Usually a Green/Yellow dual color LED.
Green - Turbo, Yellow - Normal.
One side, or can be said as color; of the LED went to Pin 2.
The other side, or other color, went to Pin 4.
Ground (Negative - ) wire goes to Pin 6.
If using a Single color LED, (2-wire), suggest connect Positive ( + ) wire to Pin 2, and Negative ( - ) wire to Pin 6.
H) Pins 8, 10, and 12 are for Bambi to use, when running around without spots...
NO!..............you gonna' believe that, geez?
I just wanted to see if you were following along, after the dual color LED thing.
Pins 8, 10, and 12 are N/C.
I) Pins 14, 16, 18, and 20 are used for a small internal speaker.
Used to hear BIOS Beep Codes.
Pin 14 is for the Positive ( + ) wire
Pin 20 is for the Negative ( - ) wire.
Also uses a 20-pin ATX main power cable, (Right side of Ram Memory slots),
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
,and a 4-pin ATX +12 Volt power cable, (Bottom left corner of processor socket),
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 03, 2013 | ASUS P4P800 Motherboard
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Jan 05, 2013 | AMD MicroStar MS-5191 Socket 7 mATX...
9VJL3 front panel
Do not have the Front Panel header pinout.
Do have;
Take an LED (Light), with two wires, and check the pins with it.
There is a Top row of pins, and a Bottom row.
Touch the first two pins in the Top row, left side. Does it light up?
No? Go to the next two pins. No? Go to the next two pins.
Keep going until the Power Supply comes on. (It is a BRIEF touch. The Power On switch is a Momentary Contact Switch )
Now you have the Power On switch pins.
LED light blinks? You have the Harddrive activity LED. (Light)
LED light stays on? You have the Power On LED. (Light)
Computer restarts? The Restart switch pins.
Short something out? NOPE. You can't hurt a thing using this method.
4 of those pins are for an internal speaker. (To hear BIOS Beep Codes with)
That's 12 of those 18 pins. (Probably less. It is two rows of 9 pins, that are stated for the Front Panel header)
4 of those pins probably won't be used.
You won't be using IR. (Infra Remote) (Only uses 2 pins, though)
Most of the time with an 18-pin Front Panel header;
Top Row:
Starting at Left side, going towards Right;
Pins 2, 4, 6, 8, 10, 12, 14, 16, and 18.
May be a pin missing in this row, or two.
Borrom row:
Same thing here. May be 1 or 2 pins missing.
Pins 2 and 4 are usually for the Power On LED. (Light Emitting Diode)
Pins 6 and 8 - Power On switch.
Pins 10, 12, 14, and 16 may be for the Internal speaker.
Pins 18, and 20 are usually not used.
Pin 1 and 3 for the HarDDrive activity LED.
Pins 5 and 7 for the Reset switch.
Pin 9 is usually reserved for the factory, and is a 5 Volt test point.
Pins 11, 13, 15, 17 for speaker; or not used. Same with pin 19.
(So speaker pins may be top row, or bottom row. Dunno )
Another thing. This motherboard is old enough to be using a 3 wire LED, or dual color; for the Power On LED.
LED usually had the colors Green and Yellow.
Yellow for 'Normal' mode, Green for 'Turbo' mode.
(Which is a bunch of cr@p.
Green LED, or Turbo Mode; was actually NORMAL.
Normal mode was the computer operating BELOW the Normal mode)
So pins 2, 4, and 6, may be for a 3 wire Power On LED.
Regards,
joecoolvette
Dec 22, 2012 | Chaintech 9VJL3 P4(478)/VIA Motherboard
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
I cleaned my pc, and disconected the wires that are right downside corner. I cant remember how to put them back rightly. Any help? hdd led power led + power led - power switch (sw) reset switch (sw)
H57H-AM2 v2 Motherboard in a Gateway DX4840 wire connections for Front Panel are shown here in Photo. I took them before I disconnected mine so it works.3_3_2012_12_10_44_pm.jpg3_3_2012_12_10_56_pm.jpg
Jun 15, 2010 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
Motherboard wire hook up I pulled the wires : Power LED, Power SW, H.D.D. LED off the motherboard, don't know the pattern to put them back on.
its simple, start from left power led next to power led is power switch, just below power switch put hdd and next to hdd put reset . thats it done.. all boards have the same module.....
Nov 24, 2009 | Computers & Internet
How to plug power switch into ASUS A8N-LA motherboard. Can't remember where power led , HD led and Power switch goes
you have a panel in the left of your ata connetor in motherboard, read there (is writen f_panel1) for apropriate led place (for example reset is writen rst, power led is writen pwr and disk led hd or hdd.)
Apr 06, 2009 | ASUS Computers & Internet
Connection Process
on your atx power supply,there is a 20 pin head wich tou have to put on a 20 pin socket on the motherboard.about the usb and other wiring,study your motherboard carefully and you will see where you will put the usb,power switch,reset switch,hdd led and power led
Nov 11, 2008 | Mercury P4VM800M7 Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Compaq for Evo D300 Motherboard
The manual can be found here. There is a numbered diagram inside. http://www.eserviceinfo.com/downloadsm/5105/Compaq_Evo%20300-500.html Hack
Jul 09, 2007 | Compaq (281946-001) for Evo D300...
EliteGroup P4VMM2 Motherboard Logo
94 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
