Question about Brunton Ped Alert Pedometer with Panic Alarm
Instruction manual I'm looking for the instruction manual on line for the brunton pedometer with panic alarm
4 Suggested Answers
SOURCE: voicezone talking pedometer instructions, turn off alarm
For the one we have, on the main screen (not in alarm set mode) it was hit the up button until it tells you the alarm is off.
Posted on Jul 29, 2010
CarlGlas
  • 283 Answers
SOURCE: I have misplaced my user manual for my Brunton
Please contact Brunton at:
2255 Brunton Court Riverton, WY 82501
USA Phone: 307.857.4700
Fax: 307.857.4702
Orders: 800.443.4871
info@bruntongroup.com
For Technical Questions: technical@bruntongroup.com
http://www.brunton.com/contact.php
Posted on Nov 12, 2010
SOURCE: I have lost instructions for
Purchased 1204 Ped Came with no instructions Please advise
Posted on Aug 27, 2011
Skmei # 1058 Pedometer watch - I didn't receive an instruction manual with my watch. I need some instruction to help set the watch...
Hi Keith
The guy in this video finds a paper manual in his package.
You can probably freeze frame it and take a screen snapshot of th manual. Cmd Shift 4 on a Mac places the screenshot photo on the Desktop
Good Luck SKMEI 1058 Waterproof Pedometer Heart Rate Wrist Watch
pedometer how to use YouTube
Mar 14, 2016 | Watches
How do you turn it off? Why is cario function shown unpredictably?
It´s hard to believe, but there is a pedometer manual search engine, they may get it within hours. Just send them a request!
Aug 25, 2011 | Brunton New PedCardio Pedometer with...
How do you change the display from metric to US
If you don't have the manual that came with the unit you may have to contact the company for the information.
2255 Brunton Court
Riverton, WY 82501 USA
Phone: 307.857.4700
Fax: 307.857.4702
Nov 12, 2010 | Radio Shack Digital Pedometer
I have misplaced my user manual for my Brunton Digital Pedometer. Do you know where I can find one? Thank you....
Fax: 307.857.4702
Nov 12, 2010 | Brunton Digital Pedometer With Pulse...
I have lost the instruction manual how do i change the setting from miles to kilometers
If you have the model, Ped Alarm - PE319, it doesn't have metric units. Correctly, Brunton sells one model programmed for metric and one with Imperial units. The units are fixed, and no conversion information is programmed into the units. The product web site doesn't come up correctly on my browsers: http://www.brunton.com/product.php?id=45. However a FAQ is available at http://www.brunton.com/faq.php . The manuals are also available here, for the Ped Alarm, click on Instruments and look in the list for that model (followed by .PDF).
I wish I could be of more help.
Oct 30, 2010 | Brunton Digital Pedometer with Alarm
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    How do you set the gaiam pedometer alarm?
    yes - after setting time for alarm, press mode and set to get alarm icon on screen
    Jun 04, 2009 | Gaiam Walking Fit Kit Pedometer...
    Brunton Ped Alert Pedometer with Panic Alarm Logo
    75 people viewed this question
    Top Brunton Exercise & Fitness Experts
    Electro Med Services...
    Howard
    Howard
    Tom Chichester
    Are you a Brunton Exercise and Fitnes Expert? Answer questions, earn points and help others
