Question about Electrical Supplies
I have a new Briggs&Stratton generator and it's voltage spikes and shuts down my inverter/battery charger when I run it.My last Briggs&Stratton works well with my system. Whats up!
  • 4 more comments
  • tomoylan Mar 27, 2009
    Cocerning
    Cocerning my
    Cocerning my new
    Concerning my new 8000w Briggs&Stratton generator,I figered it's a recall issue on the regulater board;because when I switched boards from an older generator it's size the problem stoped.
  • 13 Answers
Is that all the load on the generator? If so, it's probably just not regulating. Try loading it up with about 250W worth of lightbulbs (like one of those construction floodlights), it'll probably settle right down. The inverter charger is doing you a favor and protecting itself.
Posted on Mar 08, 2009
Briggs 6200 elite generator. Starts runs good no ac output and display is blank
http://www.ebay.com/itm/BRIGGS-STRATTON-GENERATOR-OPERATORS-MANUAL-ELITE-SERIES-6200-RUNNING-WATTS-/401042177246 $14.95
May 30, 2016 | Briggs Electrical Supplies
Bought new. No problems until two weeks ago. Now has 252 HRS. Starts all the time, runs 10 seconds then shuts down. I have removed wire an oil pressure switch. no help. Found connector off on switch p
It shuts down because it's not making power. You are probably getting a failure to start error code. If it doesn't make power it doesn
t know its running. Rotor has lost residual magnetism to start the voltage regulator. Replace the voltage regulator. The new one is designed to overcome this.
Dec 10, 2014 | Briggs & Stratton Briggs Stratton 7 kW...
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Does not Charge Battery
time to change charging system under fly wheel
did you have to jump this mower and use a car battery of high boost charger ? if so you burned out system
Nov 19, 2013 | Briggs & Stratton Garden
Put new battery on 14 hp v-twin Briggs, started and ran for a while. Shut motor off then came back and tried to start, acts like the battery is dead. Where is the generator/altenator located on these?
The generator is under the flywheel with or part of the ignition coil.
Check all the battery wiring and grounds. A bad or weak connection will act the same way.
May 22, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a Briggs & Stratton Automatic Home Generator 7 kW, Model# 40301. I had it installed by an electrician. Who also installed Briggs & Stratton Transfer Switch 50 Amp. The problem is the...
It sounds like the mains sense wire is disconected from the control panel or the run wire is not being cut by the aux contact on the transfer switch.
Is the transfer switch manual or motorised?
Feb 15, 2011 | Briggs Stratton 7,000 Watt Automatic Home...
I,ve got an Briggs and Statton elite 10000 watt generator, it wont supply enough power to the house evrything is dim lights etc, Ive used it amny times before it will pretty much run the whole house...
Does it appear to be running as fast as it always did, as in RPM's are same as usual? If there is a fuel problem and rpm's decrease due to that, voltage will drop as well. Other causes may be internal problems with generator circuits etc, and will need technician to troubleshoot it properly.
You can try increasing the throttle manually and see if voltage comes up.
Jul 10, 2010 | Briggs & Stratton Briggs and Stratton...
When I run my generator - a Yamaha EF2400S to my Zantrex Model MS2000, it will not accept the power to charge my batteries. The generator's voltage and frequency, when checked, are within acceptable...
the power coming from your generator is probably "dirty", full of spikes and surges from the generator. If it accepts shore power and not gen power, then the generator is the most likely cause. If the generator in unregulated, you are stuck, but it could have a failing voltage regulator board, or Yamaha may have a solution.
Jan 09, 2010 | Xantrex Technology Heart Freedom 25...
When my batteries run low on power the generator starts up. Most of the time the system works perfectly, but lately the inverter will click and keep clicking and the batteries will not charge, then the...
please check the voltage your generator is supplying to the to the inverter because a high voltage and frequency can make the relays in the inverter to make clicking sounds,and also do not allow your inverter batteries to run completely low before you charge it
Jan 06, 2010 | Xantrex Technology Trace Series Inverter /...
No charging voltage to battery
You can test the charger right at the battery. With the system just sitting in regular stand-by mode. If you lift the battery leads, they should have about 13.5 volts coming in from the trickle charger. If there is no voltage there, it can't charge. It would be a bad trickle charger.
Feb 09, 2009 | Briggs & Stratton 15,000 Watt Home Standby...
Electrical Supplies Logo
111 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
