Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Im trying to hook up my xbox and get on the internet by using a linksys
  • 135 Answers
Physically connect the XBox to one of the LAN connection of the router or be connected wirelessly.
If unable to connect to the Internet open these ports using the router under virtual server or port forwarding:
TCP 80, 3074 and 53
UDP 88, 3074 and 53
Note: Also the IP address of the XBox should be open to the section.
Posted on Mar 08, 2009
How to hook up laptop and xbox so u can use wireless conection for xbox live
When I tried to hook up my XBox to my desktop, I brought the "Linksys" G series wireless router. I like to shop at Best Buy, I find their sales reps knowalgeable. I not sure if the letter of the series really matters, but the security settings do. The newest securtiy settings are WEP, the older are 128 bit encryption. Find out what security setting that your XBox uses, (Read your users manual on how to do this or go to XBox.com and click on support) When you set up the wireless router connection, make sure the default value matches the XBox. After you're done, the 128 Bit encryption will give you a 24 character long code (I'm not sure about WEP) that you will have to put in manually with the controller on your XBox.
If you have access to the internet you can go to XBox. com, support, troubleshooting, How to connect to XBox Live. I hope this helps.
Dec 04, 2010 | Computers & Internet
I lost my disc to my linksys wireless g router and i just bought a computer and im trying to hook my internet
if you go to the linksys web site they have a tool that hooks up your router for you. It is much better than the cd that came with the wireless G.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
Linksys dual-band wireless-n gaming adapter + westell versalink
put all the adresses and getways(on xbox internet setings same as pc then it should work
Mar 25, 2009 | Linksys Dual-Band Wireless-N Gaming...
Cant hook up xbox 360 to internet
does this help it sounds like you are puting your cable in to the 360 and the modem you wont have a internet ligth on untill you try to connect the 360 to go live you must reset the modem
Jan 23, 2009 | Zoom X6 (5590) DSL Modem (55900003)
What is NAT type
NAT is a protocol for networking. Network Address Translation was developed to keep from running out of IP addresses. When your Internet Service Provider gives you service they give you 1 IP address which would only allow one device to be hooked to they internet. NAT allows you to assign private IP addresses to each device in your home and then translates it back to the one address your ISP provided to you. Linksys routers typically have this set by default. Are you plugging your XBOX to your Linksys router or are you using wireless adapter?
Jan 08, 2009 | Computers & Internet
I have a modem im hooking up 4 pcs to. Where does the phonelineGO
When I hook up my Linksys the way it should be hooked up I loose my internet connection on my computer. Help!
Dec 31, 2008 | Linksys Cable Modem
Xbox Live Can't Connect to Friends
Hi akemccarthy
you may need to open the ports for the linksys Router aswell
because the linksys links the belkin to the internet there using a shared connection
once youve fowarded the ports properly check to see if you have enabled the UPNP on both of the routers if they have any
heres a website showing how to port forward the ports you need opening
http://portforward.com/routers.htm
Dec 18, 2008 | Microsoft Xbox 360 Console
Hi i have a satellite internet provider and im trying to set up my linksys broadband router so i can hook up my xbox 360 my problem is everytime i hook it up im getting no internet connection can you tell...
hi,
there are two things to be addressed in this case.firstly you have a satellite internet provider which can create consistency issue.then when you connect a xbox to router you need to do a port forwading on linksys router(port forwarding=opening ports in router so your xbox can communicate freely).in order to do the port forwarding you have to log onto router user interface.then go to applications and gaming tab,where you can do the port forwarding.
but before doing so,you have to contact microsoft to know the ip address assigned to the xbox and the ports(numbers) to be opened.
thank you.
Nov 27, 2008 | Linksys Wireless-G Broadband Router
Im trying to connect to xboxlive.im connected to the internet,my xbox 360 keeps failing to update
It depends how you are connected to the internet an easy way that i did it with is by connecting it through my ethernet connection in the back of my computer then connecting through the internet with the blue USB cord that comes with your internet connection if you bought DSL. but if you have broadband there are a few ways if you have a linksys and your internet is traveling through there then you can just plug in the ethernet cable to one of the connection areas still available in the back of the linksys. Now trying to connect wireless to xbox live can be a little different and depending on the reason xbox live gives you for not being able to connect it could possibly be a problem with your computer but i can still help you with that so just post something else about it and tell me how it goes also if you get it working you should send me a friend request or tell me your name because i usually have around the max of a hundred friends so a friend request wont work.
Mar 07, 2008 | Video Game Consoles & Games
Xbox 360
does you computer work?
Feb 22, 2008 | Microsoft Xbox 360 Console
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
100 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
