Question about Frigidaire FRS23R4A Side by Side Refrigerator
Refrigeraor door "thunks!"
Seller delivered new "used" model, and had to remove the doors to get into house. When I open the fridge door, it "thunks" when the door reaches the dedent point. Sounds like it is dropping into position Only does it when opening; if opened fully, does not "thunk" in the return.
Do you suppose the lower bearing hing was put back on ****-eyed?
    President:
  • Frigidaire Master
  • 2,651 Answers
That s what sounds like, either it cracked upon removal/reinstall. or perhaps it justneed to be tightened. its a seperate "cam lifter and riser" that gives yo the self closing action. strictly an annoyance however, no fearof door falling off
Posted on Mar 08, 2009
I have just had a Hisense Black Glass French Door fridge delivered. It will not fit through the door way. Can I remove the doors. There is no external water/ice dispenser
try this trick
instead of trying to get the fridge through full on or sideways
put the fridge side on to the door way then open the fridge doors first
that reduces the fridge width by the thickness of the doors and the body of the fridge can be maneuvered through the door way and turned slightly at the last bit to allow the door and hinges to get past the door jamb
You can take the doors off but you have to be sure that on reassembly the doors are sealing properly and adjusted correctly
Jan 24, 2017 | Refrigerators
My kenwood kfc60ss15 fridge freezer that was delivered today.
Contact the seller of the fridge, we are not them.
Nov 22, 2016 | Cars & Trucks
Can you remove doors on samsung sr-l626ev?
it may not be necessary to remove the doors
open the doors fully and slide the fridge sideways through any door , one open door first , fridge then second door
Jun 23, 2016 | Samsung CoolTech Plus / Basic Bottom Mount...
Looking for a rubber to fit around the door of the fridge , do you know where in australia they can be bought . thanks . julie herring
Here is a link to an Australian supplier of Hoover fridge door seals:
http://www.doorseal.com.au/fridge-seals/hoover
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Not sure if you can pick it up locally yourself, but you can certainly order one online and have it delivered. Just look for your specific model number at the above website.
Good luck.
Mar 21, 2011 | Hoover Refrigerators
Removing doors from a Maytag fridge
first try to open both doors and slid it threw the door. slide it threw like a c if you know what im talking about. i sold ge and westing house at the local goodyear tire store foe 19 + years. it worked for me.
Nov 03, 2009 | Maytag MTB2195AE Top Freezer Refrigerator
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
GE fridge doors open and close
Raise the legs up on front till the machine tilts slightly towards the wall. The weight of the doors will then be shifted towards the machine instead of away from it. Only a slight adjustment is needed and should have been done by the delivery guys. A $5 tip would have gotten that done, you must be a cheapskate.
Source: I used to deliver them before I learned how to fix them. LOL
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
New refridgerator delivered this morning to replace the same model that was a lemon. The fridge is making a sound on the fridge side. When I open the door to the freezer side the sound stops. When I...
sounds as if there is an issue with the evaporater fan motor, perhaps the fan blade has come dislodged and is makinf noises, normal for the fan to stop when the frig door opened as welll,
Dec 17, 2008 | Refrigerators
Frigidaire FRS23R4A Side by Side Refrigerator Logo
87 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
