Question about Insignia 42" LCD Flat-Panel HDTV
I have 42 insignia NS-42pdp I have sound but, no
I have 42 insignia NS-42pdp I have sound but, no picture
  • Anonymous Apr 12, 2009
    I have static sound but no picture. I cant even see the vulume or channel. There is a little purple haze at the bottom of the screen. There is no warranty on this tv anymore. Can anyone hlep me?
4 Suggested Answers
  • 2336 Answers
SOURCE: Insignia NS-LCD37-09 turns on but no image
If your TV is less then a year old, still under manufacturers warranty. If not under warranty the defective parts could be the power supply or the back light inverter board. Both boards can be replace easily.
The way to know if you have a defective backlight inverter is by shinning a light from a flash light near the screen with the TV on and check in a 45 degrees angle if you have a dark video in the background, if the video is present then you have a backlight board failure. If no video, then is a power supply failure.
I have both boards if you want to buy them.
Let me know if you require further assistance.
Posted on Jan 08, 2009
ginko
  • 19396 Answers
SOURCE: Insignia NS-32LCD has sound but no picture -
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Jul 18, 2009
  • 161 Answers
SOURCE: Insignia lcd tv model ns-ltdvd26 has sound but no picture
the pic attached is an electrolytic capacitor, they come in different sizes and are usually blue, black and sometimes yellow. depending on manufacture.
most of the problems I have heard of tvs having problems with the electrolytic capacitors going bad. if you open the tv and see one of those swollen or leaking you need to replace them.
Posted on Feb 13, 2010
I have a insignia model ns-42pdp i have sound but no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 03, 2016 | Insignia Televison & Video
Tip
REMOTE CONTROL CODES FOR THE INSIGNIA TELEVISION MODEL: 42" NS-LCD42HD
This information was found on the insignia website www.insignia-products.com under technical information for the insignia television model :42"1080p NS-LCD42HD. cablevision-ur2-cbl-cv04.gifaligner.gif CableVision UR2-CBL-CV04
code: 096
charter-digital.gifaligner.gif Charter DIGITAL
code: 0463
comcast-m1057.gifaligner.gif Comcast M1057
code: 0463, 10463
cox-cox.gifaligner.gif Cox COX
code: 0463
direct-tv-rc23.gifaligner.gif Direct TV RC23
code: 10463
dish-network-vip508.gifaligner.gif Dish Network VIP508
code: 720
dish-network-vip622.gifaligner.gif Dish Network VIP622
code: 720
motorola-drc800.gifaligner.gif Motorola DRC800
code: 0463
one-for-all-urc-6690.gifaligner.gif One for All URC-6690
code: 0464
phillips-pdvr8.gifaligner.gif Phillips PDVR8
code: 115
phillips-ph5dss.gifaligner.gif Phillips PH5DSS
code: 115
phillips-ph5dvd5.gifaligner.gif Phillips PH5DVD5
code: 115
phillips-pmdvr8.gifaligner.gif Phillips PMDVR8
code: 115
rca-rcu807.gifaligner.gif RCA RCU807
code: 135
sony-rm-vl600.gifaligner.gif Sony RM-VL600
code: 8043
tivo-hd.gifaligner.gif TiVo HD
code: 0091
tivo-series-3.gifaligner.gif TiVo SERIES 3
code: 0091
on May 23, 2009 | Insignia 42" LCD Flat-Panel HDTV
Insignia NS-42PDP plasma tv turn off on its own and can't be turned without disconnecting power and the restarting
You possibly have bulged capacitor on power supply, just replace it to fix the problem
Dec 03, 2012 | Televison & Video
How do you widen the screen on insignia ns-lcd 37-09
your looking a picture format or picture resolution menu it should give you several options in the form of ratios or an automatic adjustment feature
Hope I helped
please leave feedback
thanks
Robb
Apr 16, 2010 | Insignia 42" LCD Flat-Panel HDTV
Red Snow
Sounds like you know what your doing so i won't get over technical on ya ! Diffusion is the name for the problem.Adjust the VA and VS, if that doesn't cure it the panel is bad.
Jun 11, 2009 | Televison & Video
Insignia ns-32lcd. picture scrolling and no sound
Hi, I was waiting your response in chat session but didn't get any.
Cracked plasma screen
honestly probably not worth it
May 31, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Insignia 42" LCD Flat-Panel HDTV Logo
718 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
