Question about Symantec Norton 360 for PC (037648318846)
Was 360/2.0 0r 360 installed? ordered 2.0.
Took 6 weeks to stumble across removal tool.finally installed,but says only 360 version. spent 4 hrs to get to here! is it installed?,if not, now what? i am a comp.novice. ordered 360/2.0
  • 3,051 Answers
Hi there
have you tried to go to this is a norton technical site that deals with all of the issues with norton
Posted on Mar 08, 2009
Here's a link on removing the belt,then remove both screw holding the tensioner on. GET 35 GIFT CARD FOR EVERY 100 SPENT ON ONLINE SHIP TO HOME ORDERS Here's the tensioner... It take's two people to remove and install the belt,one removes tension,the other removes the belt.It's possible you may have to get under the front end to take tension off of belt with the tool.
Aug 14, 2015 | Suzuki Cars & Trucks
Superior tool 37100 blade replacement
From Superior Tool Website, look up the tool, then click on "How to Use".
Blade Replacement:
1. Remove large pivot bolt and nut
2. Slide blade down through handle
3. Remove one (1) end of coil spring
4. Remove "E" clip from 1/4" pivot pin,
remove pin and blade
5. Install in reverse order
6. Torque nut until tool ratchets correctly
Mar 13, 2013 | SUPERIOR TOOL CO superior tool 37100...
What is the firing order for the spark plugs in a 96 pontiac bonneville i think i have them mixed up because my car wont start
If 3800 engine the timing is 1-6-5-4-3-2
If 2.8L or 3.1L or 3.4L timing is 1-2-3-4-5-6
Coil packs on 3800 are (1 / 4, 5 / 2, 3 / 6)
Coil packs on 2.8L or 3.1L are (1 / 4, 6 / 3, 2 / 5) 1995 earlier across the front from right to left.
Coil packs on 3.4L are (5 / 2, 3 / 6, 4 / 1) 1996 across the back from right to left.
Feb 06, 2011 | 1996 Pontiac Bonneville SE CA Value
I have accidently blocked my profile pictures and I do not know how to fix it could you help me?
Hi, Please try the below steps if you are using Internet explorer as browser:- 1. Go to the "Tools" menu
2. Choose "Options"
3. Click on the "Content" tab
4. Across from "Load images automatically" click "Exceptions"
5. Highlight the Facebook URL
6. Click "Remove site"
7. Close the Exceptions window
8. Click "OK"
9. Restart your browser
And if you are using Mozilla Firefox please try the below steps:- 1. Go to the "Tools" menu
2. Choose "Options"
8. Click "OK"
If you don't see an "Options" selection in the "Tools" menu, you will need to follow these steps:
1. Go to the "Firefox" menu
2. Choose "Preferences"
8. Click "OK"
Best wishes for your effort.Thank you for your time and patience.
Nov 12, 2010 | Facebook Social Network
Error 7149 Quickbooks
Thanks, that worked! I first spent a half-hour on the phone with the non-tech support at Intuit and he walked me through that download. What the download does is update your original QB 2005 RC1 version to the RC9 version ("Release Candidate") where they've fixed some things (such as the Flash 7 install problem). Here's what we did:
1.) Removed Flash ActiveX 9 in Add/Remove Programs
2.) Downloaded webpatch from QB site (start here:
3.) Closed QB (couldn't open it anyway)
4.) Installed patch.
5.) Restarted computer.
6.) QB worked!
Thanks for your postings. I hope this helps.
May 07, 2010 | Intuit QuickBooks: Pro 2005 for PC
Not able to enter phone number under new receipient dia
This usually occurs after an Internet Explorer upgrade. I spent days banging my head against the wall searching for solutions, when I stumbled across this. It fixes the problem every time.
WinFax PRO hangs or shuts down
- during installation
- when prompting for a phone number/CSID
- editing a phonebook entry
- adding/editing an IP address, or setting up Host Sharing
The problem started occuring after installing Internet Explorer 7/8.
2. Click on the LANGUAGES Tab.
4. Click the ADVANCED Tab.
5. Under System Configuration, enable the option "Turn off advanced text services" (Put the CHECK mark in this box.)
6. Click OK.
7. Restart the computer and then try WinFax PRO / TalkWorks PRO again. Number entry should now work in WinFax.
8. Now go back to the control panel following the steps above and undo step 5, un-check the option "Turn off advanced text services."
• To open Regional and Language Options, click Start, click Control Panel, click Date, Time, Language, and Regional Options, and then click Regional and Language Options.
• Use this procedure to turn off handwriting recognition, speech recognition, and some accessibility features temporarily. These services can affect performance, and if you are not using them with your current program, you can turn them off temporarily.
• If you are not using a text service at all, you should remove it.
• Turning off text services does not affect multiple languages or keyboards that you have added under Installed services on the Text Services and Input Languages dialog box.
Aug 29, 2009 | Symantec Winfax Pro 10.03 (winfax10.03)...
Took plugs off distributer cap cant remember order
2.4L Engine
Firing order: 1-3-4-2
Distributorless Ignition System
3.0L Engine
Firing order: 1-2-3-4-5-6
3.3L & 3.8L Engines
Jul 24, 2009 | 1991 Chevrolet C2500
How to turn on the wireless on a dell inspiron 1501
i just spent 6 hours the other day repairing this exact same laptop for my friend, should have taken an hour,hopefully you have right clicked on the network adapter and enabled it in the device manager,everything appears to be installed correctly but its not,,open the flap on the bottom of the laptop,square door 2 phillips screws,physically look at your wireless card to see witch one it is write down the mdl no.probably broadcom but maybe intel pro, makesure,dont just trust the dell support site and type in your service tag and take what they give you.,also there is a update at the amd web site for this processor to help resolve this problem,uninstall your network adapter completley,check add remove programs for broadcom software,uninstall it,(or intel witch ever one you have)restart check the control panel make sure its gone,change the view when your in there sometimes it hides.get the amd update install it ,restart,go to the dell support site type in service tag,go to drivers an software over on the right of the screen where it lists all your drivers ,learn more about drivers and the order to install them,read it ,go back to the driver page ,if i remember correctly there were three or four downloads for broadcom wireless ,a couple for intel ,and ricoh, i dont know why so many options for a single service tag,usually dell,is pretty good..i fix 3 or 4 laptops a week ,been doing this for a long time(20 years or so)this model with this chip is stubborn,took about 4 tries before it worked ,if you down load the wrong one first it wont work even though it finds the adapter and installs it correctley,and says its working properley,its lieing to you ,uninstall it restart and try it agian changing the order you install the drivers and software,utilities first,network adapter ,then wireless driver last ,i think that was what finally worked,can't exactly remember that was about 5 laptops ago ,good luck
Jul 06, 2009 | Dell Inspiron 1501 Laptop
I'm trying to copy old family videos from VCR to DVD. I'm using the correct disc type (DVD-R) and there's no copy protection. I've tried both Sony and HP discs. Each time, it seems to be working but...
First, try to refinalize the disc if it failed the first time by going into the edit menu. Sometimes finalization just fails the first time.
If you are recording on 2-hr mode, and the length of your recording is an 1hr 50 min or more, there will not be enough space left on the disc to finalize. Going forward, your best solution would be to record in 3- or 4-hour mode for every 2 hrs worth of recording (6-hour mode for 3-5 hours of recording, etc.). Just to quickly decipher recording modes: 2-hr mode (sometimes called SP Mode, depending on DVD player) will record about 2 hours worth of material on a standard blank DVD (but some extra space would be required for finalization); 4-hour mode would record 4 hours worth of material on a standard DVD; 6-hour mode would record 6 hours, etc.
As far as salvaging the recordings you have already made - load the burned, yet unfinalized DVD's into your computer. Copy the files onto the desktop or some easy-to-find location on your computer. Then use a program, free or otherwise (I personally reccomend Nero or Roxio), to re-burn the discs. The newer version of Nero automatically finalizes the disc, but some software requires you to select an option that allows you to "close disc" or "finalize" the disc. (In computer lingo, "closing" means the same thing as "finalizing").
-Tha Mp3 Doctor
Mar 04, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Order #772461524 chgd 7 Mar-08 I've spent over 8 hrs trying to install, last effort my computer stalled on removing the Norton installed for p7 and now I NEED HELP!
Apparently more time and patience solved the problem, at least their have been no more prompts to choose a product, after I have already paid.
Mar 11, 2008 | Computers & Internet
Symantec Norton 360 for PC (037648318846) Logo
Top Symantec Computers & Internet Experts
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
