Question about Zenith C34W37 34" TV
Hello I have a zenith c34w37 that has sound but no picture. When I turn it on the front panel led flashes 6 times. Please help!!
TVtechmaniac
  • 140 Answers
SOURCE: ZENITH P42W34P does not turn on
I have a pdf file of the service manual- if you want it, let me know where to send it.
Posted on Sep 11, 2007
SOURCE: tv wont stay on
Replace the bulb. I got my bulb from Samsung Parts for $125. Worked perfectly
Posted on Jan 23, 2008
  • 8068 Answers
SOURCE: Hello: For unknown reason, now my aged Zenith VCR
Just a hunch. Look for a cleaning casset and use it to clean the heads.
Hope it helps.
Posted on Sep 15, 2009
  • 27 Answers
SOURCE: BLACK SCREEN,JUST SOUND HELP!!!!!!!!!!!!!!!!
a lot of those get a bad Y board or panel driver. sometimes both.
Posted on Apr 09, 2010
SOURCE: rear projection tv wont come on. PLEASE HELP
hi i have a zenith 65 inch dlp z62dc1d tv, it does not turn and there is a blinking green light that changes to red.can any pleas advice me what seems to be the problem
Posted on Jul 21, 2013
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
When I turn on my Zenith Plasma it flashes for a split second and goes blank. No picture or sound. I have tried a different power cord but to availe.
My 42" zenith would try to turn on then go back off. LED would go red back to blue. I replaced the YSUS board and it works again.
Jan 10, 2013 | Zenith Z50PX2D 50 in. Plasma HDTV
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Won't turn on - relay clicks, power supply squeals, relay clicks, etc,
The television has a protection circuit. Sound like you know something about electronics so that is cool.
I suspect the HOT or High Voltage Transformer. If you want to operate on it, they typically will short externally from moisture or plastic high voltage breakdown. The TV starts, shorts as it cannot come to full high voltage, then shuts down. If your brave, you can unsolder the HOT which is the part that is on the main board or that comes from the top of the picture tube wire into a dark or spaceship type object.look underneath, sometimes they short underneath and you can scrap the carbon and get it to at least start up and work. Do not leave this as a fix as it can be a fire hazard.
The HOT is the most common. They are around 20-60 bucks. 34" TV. I am assuming this one without looking it up it is NOT a flat screen, as most do not squeal like that nor do they have to de-gausse like the old ones. I just looked it up and yes it is not a flat screen. Old school, so that is more thank likely the problem.
Mar 02, 2009 | Zenith C34W37 34" TV
Reset lamp counter for zenith z52dc2d
Go to stand-by mode press "?" key on remote. then press 9 8 7 6 and the ok button. the 3 led lights will flash to verify the lamp timer was reset
Oct 30, 2008 | Televison & Video
need check B+, standby power supply, and Horizontal defletion and components
Oct 23, 2008 | Zenith C34W37 34" TV
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Tv wont stay on
Oct 18, 2007 | Zenith D52WLCD Television
Hdtv won't turn on
Can you count how many times it flashes ? It might flash like 6 times and pause for 2 sec and flash 6 times again. THen call a service comany and tell them this info and they might tell you what part inside is bad. They are not telling you this for you to replace but they might say something like oh 6 flashes is a Y board and we will have to order it.
Hope this helps
Aug 29, 2007 | Televison & Video
Zenith C34W37 34" TV Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
