Question about Bosch Drills
Hammer drill only works when you tap on it with a hammer
I have a Bosch 11210VSR Bulldog hammer drill (SDS), and I was using it a lot one day and it altogether quit on me. I felt it and it was pretty warm, so the next day I tried it, and now it will weakly run if you tap on it with a hammer. I was wondering if you know what is going bad, if it is the trigger, or motor, etc? I havent torn it apart yet, is there something I should look for?
  • 201 Answers
Yes, check the brushes on the motor, see if they can be replaced - I don't know your drill, but some can be checked without pulling the case apart - look for a round slotted cover on the sides near the rear of the drill
Posted on Mar 08, 2009
  • John Aman
    John Aman Mar 08, 2009
    Actually, it appears you will have to take the case apart to inspect the brushes.....
What type of oil for bosch 11224vsr rotary hammer drill
special grease is used not oil order number 1 615 430 001 is the right grease for it
Apr 08, 2013 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Runs but doesnt engage rotary or hamer. the machine itself looks in great condition its called bosch buldog extreme.
there is a selector knob on the side that controls the tool functions for drill only/hammer with drill/ and hammer only. make sure it is in the proper setting. If it still doesn't rotate then you have a gear or a broken selector. If no hammer then you have worn o rings or a stuck ram. try the selector first and if still no change please be more specific if no hammer at all, or no rotation even when selector moved.
Mar 03, 2011 | Bosch SDS-plus BULLDOG Xtreme Rotary...
SDS drill bits slips frequently
Take a look down the nose and see if the tabs 180 degrees from each other that accept the bit are in good condition. If they are it is possible that the clutch is slipping (321/22 and 321/37 fit together to create the clutch along with the ring that 321/37 fit into). Please let me know what you find.
Nov 20, 2010 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
How do I insert a bit into the chuck on a bulldog xtreme hammer drill?
There is a collar that you have to pull back, it is kind of big. Be sure to rotate the bit, as you install it, sometimes tricky to engauge the last tiny 1/2 inch or so. The tool will be retained, but not engauged.
Sep 17, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Bit will not come out of the end of the hammer drill.
If the chuck will loosen and the bit still won't come out try tapping firmly on the tip of the bit with a scrap of wood while the chuck is loose. There are a couple ball bearings in the chuck that stick sometimes.
Feb 15, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Hammer action power there but weak
It is hard to understand what you are asking, however I have found that with the SDS drills one does NOT want to crowd them but just let the tool work with light pressure...
Feb 07, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Looking to add oil to rotary hammer Bosch / Bulldog
the oil seal is broken, remove front cover at the chuck end of the drill, and replace the seal,
Jul 21, 2009 | Bosch SDS-plus BULLDOG Xtreme Rotary...
What do I need to replace the brushes in Bosch Bulldog 11210VSR
Were the brushes severely worn? It's really only the brush that you need to replace, as long as the spring didn't come into contact with the rotor and get worn.
Mar 08, 2009 | Bosch Drills
Drills Logo
272 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
