Question about Philips 50PFP5332D 50 in. Plasma Television
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
  • 53 Answers
The Philips 50'' Plasma TV model 50pfp5332D/37
has only one main board
has many sub bords supporting tat main board
Posted on Mar 08, 2009
Philips TV, Model Number 50PFP5332D/37, the screen starts out all black, but then slowly the black starts to dissipate and the picture starts to come through. However, the picture is all gray & fu
You more than likely heard a pop noise when this failed, the infamous pop of death when the Y sustain module fails. First check the various fuses located on the Y and X sustain modules. If a fuse is open you have lost the large IC on either PC board. These boards are located left side 3 module and far right side module with ribbon cables attaching to display panel. This can be a complicated repair due to one of the buffer modules failing, The Y sustain will be identifies by Samsung drawing number LJ92-01200A, The Buffers are LJ-92-01202A, LJ92-01203A. This is most likely a job for a pro because 1 of or all 3 modules can be at fault. Some services on e-bay for these modules offer rebuilding the Y-main module and also testing the Y-buffers. If you want to DIY this TV this would be the best Idea, send three boards to a rebuilder on E-bay.
Mar 05, 2013 | Philips 50PFP5332D 50 in. Plasma...
Philips 50'' Plasma TV model 50pfp5332D/37 GREEN BLINKING ON LOGIC BOARD
Main digital processor IC on the board has damaged. It is not a replaceable part, as normal soldering techniques cannot be applied to de-solder it out from the board, or to solder a new one in place. Card base replacement should be done.
Aug 14, 2012 | Philips 50PFP5332D 50 in. Plasma...
I have a 50" plasma Philips tv 50pfp5332d/37 it
Most Common problem is Bad Capacitors on the power supply board, they will be vented or swollen on Top. 1000uf 16v 2200uf 10v 3300uf 10v
Jun 25, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
We were watching tv last night and it the picture just turned off. the machine was on but no picture. i turned off the tv and tried again this am. no picture.
You either need this part (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ92-01401-Buffer-Board-/150501144120?pt=LH_DefaultDomain_0&hash=item230a913638) or this one depending on your dead screen issue (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ41-04216A-X-SUS-XSUS-Board-/170550290208?pt=LH_DefaultDomain_0&hash=item27b596e720)
Oct 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
Where can I get a video board for a 52'' Philips plasma TV, model #50PFP5332D/37 ????? I found one, but it only lasted 6hrs. Need quality board.
I have original philips videoboards for pfp 5332d, they shoud last normally, maybe the powersupply voltages not proper to it.
Feb 25, 2010 | Philips 50PFP5332D 50 in. Plasma...
Half of my screen plasma TV 50" is black. What I have to do to fix it? plhilips plasma tv model 50PF7321D/37
Your Television problem on vertical section.
Solve: If you repair itself replace vertical IC or thoroughly resolder dry any components.
Jan 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
I have a phillips 50 inch plasma- model 50PFP5332D/37- when its plugged in it makes a clicking noise and the light is on indicating it is on, but picture never comes on- help
you have a problem on one of the boards in this unit you would have to start isolating the source to pit it down
its probably best you get some help form a servicer in your area this is a philips inside and made by samsung
Oct 23, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
My 50PFP5332D/37 Philips plasma tv stopped working. The TV turned off while I was watching it and now there is no power coming into the tv. I unplugged it for a few hours and tried plugging it back in...
You may need to replace the Y-buffer to say the least. And if this is not the problem, you will need to replace theY-main board. If the Y-main board is bad you will also change the Y-buffer. Please see a Philips Tech!!!
Mar 11, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips 50PFP5332D 50 in. Plasma Television Logo
811 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
