Question about Coleman Powermate Powermate 5000W Generator
Powermate 5000 leaks gas from the air filter..not sure how it's getting into the air filter?
  • Anonymous Mar 15, 2009
    I replaced needle and seat with the same result. the float does not appear to have any holes in it and is not full of gas
My Coleman Generator 5000w with a Tecumseh 10hp story. Mine engine finally did die before I pulled the carburator off.
On mine the float was defective. It was full of fuel! I repaired the hole in it. I removed the air filter and saw fuel pouring out the side so much that I had a jar to catch it. I removed the carburator and took the nut off the bowl to examine the float. Then I removed the pin holding the hinged end of the float. Carefully pulled it out with the needle valve attached. When I removed the needle valve (just slides on mine) it was free to test. I tested by shaking it near my ear and I could hear the fuel inside the float. Mine was brass or copper. I wiped mine off with a napkin and finally found the hole. I drained the fuel by polking a needle sized hole and removed the fuel. I then soldered the hole shut with using just electronic 60/40 resin solder and a small soldering iron. Mine works like a champ now.
Posted on Mar 09, 2009
I'm not an expert but I have a 10 or 12 year old Coleman 5K Watt generator with a 10HP Briggs & Stratton OHV engine. Model: 204412 Type: 0136e1 Code: 030102yd. It was leaking gas from the air cleaner and stalling when this happened. We were convinced it was the carb. We took it all apart and cleaned it. It still spit gas. Ended up buying a new nikiki carb and after installation ($93.00 later) it still spit gas. BTW the rebuild kit for the carb was within about $30.00 of the whole carb and that was why we bought the whole new carb. We had cleaned out the fuel tank, installed an in line filter, etc. Anyway the problem turned out to be something simple and stupid. Right at the nipple fuel inlet of the carb, the was a tiny crack in the fuel line hose, more than likely a 3 or 4 dollar item. I cut the fuel line at the crack and like magic no more spitting gas and it runs better than new. One more thing, those of you who have knowledge of these types of issues, please continue to share them instead of forcing people to PAY an "EXPERT" for their miracle solutions. Thanks!
Posted on Jul 03, 2011
  • 2,692 Answers
The float of the carburator is set incorrectly or sticking open, allowing the fuel to leave the bowl go into the throat and onto the filter. Ajust  and /or clean float, needle and seat.
Posted on Mar 08, 2009
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ... > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Hi! I have a Coleman Powermate 5000 maxa er plus. It wouldn't start so I check out the air filter, it was kind of dirty and I found gas in it. I cleaned my carburetor with carb cleaner even if it was clean...
The engine is pulling secondary air from the torn gasket area by the sound of it. It can't govern itself like that.
That must be fixed before any further tests !
Aug 19, 2013 | Coleman Powermate Powermate 5000W...
My powermate 5000 with subaru engine will run anywhere from 30-60 minutes and shut down. One light pull to the pull start and it runs great for another 30-60 minutes. Never a problem to start it back up...
There is debri or dirt in gas tank and eventually it gets sucked up and clogs the screen filter on the end of gas line. Drain gas tank and flush out a few times. let dry and put new gas in it. check your gas can, if it is metal, it may have rust in the bottom of it and it goes in the gas tank and clogs screen, make sure you have a clean gas can that you use to fill the generator.
Aug 25, 2011 | Coleman Powermate Subaru 5000W Portable...
Is there a gas filter on coleman 5000? runs until hot then shuts off
There is somewhat of a filter inside the tank, however your issue could be air lock or faulty oil sensor. Try running the generator with gas cap loose to allow more air into the tank. If cap is fault try to clean cap vent ports with carb cleaner or just replace the cap. If not fuel lock, remove wire from oil sensor and test again.
Nov 04, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
I bought a used coleman powermate 5000 generator, I replaced the spark plug and fuel filter, it finally started up,it would only run in the "choke" position it ran about 10 minutes and then shut down, I...
What brand of engine & horsepower is it?Also about how long was it stored or last time it was run? The reason I ask is if it was stored with gas in it & a fuel stabilizer wasn't added to it,your primary jet is plugged in the carburetor(reason it will only run while choked).
Jan 07, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000 starts with starter fluid, but leaks gas into the air filter. Checked the float, it has no holes, and is not jammed. Fuel will go into the carburetor, but no fuel will reach the...
Sounds like you need to clean the carb ports, lines, jets, etc... purchase a carb spray cleaner with a tube to place on the spray head (Berryman's Chemtool B-12 is awesome). Take the carb loose from the generator, and remove the bowl, needle valve and spray carb cleaner thru all the holes, lines in the carb. Reinstall complete with air cleaner and retry... also if the gas is old, drain and replace with new...
May 25, 2009 | Coleman Powermate Powermate 5000W...
Engine dies
Your carburator is gummed up !
Take the float bowl on the bottom of the carb and spray the main fuel jet out with cleaner, do this to the idle needle valve also. If that don't work pull the carb & take apart & soak overnight in parts cleaner & blow out all ports & orfices with compressed air.
Next time you store your generator with gas in it , use a fuel stabilizer !
Good luck !
Oct 05, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
1,275 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
