Question about Toshiba 57H81 57" Rear Projection Television
My Toshiba 57H81 has a 'jittery' picture.
Hi, I have a Toshiba 57H81 projection tv. The picture looks like a sound wave from on a scope. It is 'jittery' right to left. If I use the POP and bring up the 2nd picture, it is crystal clear, even on the same channel. However the first picture remains 'jittery' and wavey. Any ideas?
  • amadflyer Mar 08, 2009
    What resistors am I changing? I have not done any repairs yet.
    Problem Solver:
  • 4 Answers
I have the same prob need to change the resistors as a first resolution. there should be 5 of them, if you dont soon and i mean soon you could cause the skt to go bad and have to start over in your repair
Posted on Mar 08, 2009
Toshiba 2002 projection tv 57h81 has red light no sound no picture
Projector TV's have a tube for each function e.g. Video 1, Video 2, TV. Does the TV just not work or the VCR<DVD<Game console modes not work as well? If one works and the others do not you should be able to replace that tube, module, piece.
I hope this helps.
Oct 21, 2013 | Toshiba 57H81 57" Rear Projection...
Hi, our toshiba rear projection tv will turn on but no picture. whats the problem? thanks
MODEL NUMBER 56H80 TOSHIBA PROJECTOIN TV,PICTURE IS NOT COMING AT ALL
WHATS THE PROBLEM
Feb 04, 2011 | Toshiba 57H81 57" Rear Projection...
No Sound on Toshiba 57H81 projection TV. Picture is fine.
The sound amplifier IC has went bad and needs replaced. Call a good TV Tech.
Check with the BBB 1st before you decide on one.
Jun 19, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba Projection Television Problems
we are facing server problems please reply to me at coolguy4u_008@yahoo.com
don't worry i have found your part..
Apr 11, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 Image Problems
Hyper module - need to rebuild them though they are NLA and have been for some time...
Bill
Premium Technologies
premtech@willapabay.org
Feb 18, 2008 | Toshiba 57H82 57" Rear Projection...
57H81 Toshiba
Go to an unused inut...bring up the menu.....if its clear, its the hyper board........if it blurry......its a convergence problem.
Jan 11, 2008 | Toshiba 57H81 57" Rear Projection...
This is a common fail for a Toshiba 57H81 the cause most likley is caused by the Hyper board, there are several capacitors that have weakened and need to be replaced, these are surface mounted and have VERY Fragile contact points, if your soldering skills are week you might want to take this somwhere to have it fixed
Dec 26, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81
Check all fuses in the power supply and look for any bad connrctions on the PCB. You are probably missing the 130 volt supply to the horizontal circuit. Common reasons are: Shorted horiz output transistor; flyback transformer, picture tube arcing , bad power regulator IC. In short, you need to get a qualified tech for this symptom. Hope this helps.
Oct 29, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 picture bounces. Can't tell if horiz. or vertical.
Unstable picture, wavy, jittery, and loss of sync are a symptom of bad capacitors in the hyper module. The problem is worse when the set is cold, but when warm the sympton gets less or goes away. In the latter stages the problem never gets better even after the set has been on for hours. There are about 6 surface mounted caps (10mf/16) inside the shielded Hyper module. The module is vertically mounted behind the jack panel and can be unplugged from its socket after unsoldering the 4 anchor tabs on the bottom side of the PCB. This type of repair should be made by a qualified technician do to the complexity of chassis removal and expert soldering skills.
Oct 25, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
189 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
