Question about Mantis Tiller
When i press gas lever it dies --mantis tiller
  • 15 Answers
Try checking the spark arrestor inside the muffler. They often get clogged and will not allow the exhaust to escape easily. I had this same issue and spent bou coup cash trying to fix the carb and intake side, then when I was going to check the compression, I removed the 3 screws on the muffler cover and 3 more screws on the spark arrestor and found the little screen was clogged. I cleaned it with carb cleaner and ... VOILA...problem solved. I hope this helps. If you call the company they will recommend a carb kit. Try the spark arrestor first (cheaper and easier, too). I hope this helps.
Posted on Jun 03, 2009
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
Stihl mini tiller idles but won't accelerate
check to see if cable is in one piece, not broken! look down where it hooks to the engine while accelerating, you should see a lever move on engine, if so then it may need the accelerate adjusted!
May 28, 2014 | Mantis Gas Mini Tiller/Cultivator, 2 -...
2 stroke Mantis Tiller 1) Very difficult starting, when started, high rev works, but 2) Engine dies on deceleration. Carburetor is signed C1U K4589A. The priming pump does not suction, gasoline...
Hi there is a small stone fuel filter in the tank. this filter stops fuel from running back into the tank from the carb check to insure it still on and make sure there are no cracks or hole in fuel line that should fix your problem
Aug 31, 2011 | Mantis 2-Cycle Tiller
How much gas to mix the oil in?
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Sep 08, 2010 | Mantis 2-Cycle Tiller
I replaced the fuel filter but the purge pump
Faulty valve inside it. Try stripping it down and gently blowing into it.Do not use compressor air as it may damage the valve.
Mar 17, 2010 | Mantis Tiller
Tiller would start then quickly dies.
If you look inside the gas tank, there is a small little gas filter attached to a small plastic tube.
Fish the gas filter out with a small wire.
Replace the filter with a new one.
Please let me know if that works.
Jan 28, 2010 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I had my 2 cycle tiller at a shop and he told me
Mantis Product Owners Information
spacer.gif arrow_red.gif Submit your Question spacer.gif Please Select a Category Below arrow_green.gif Mantis Tiller/Cultivator Gas Tiller FAQ (12) arrow_green.gif Mantis SprayPartner and SprayMate FAQ (7) arrow_green.gif Mantis Blower/Shredder/Vac Service FAQ (3) arrow_green.gif Mantis ComposT-Twin FAQ (10) arrow_green.gif Mantis Edger FAQ (7) PARTS
If you need parts, or wish to return a product, please call our Customer Service Department at 1.800.366.6268
Hours are Monday through Friday 8:00 AM - 5:30 PM Eastern time.
Jun 07, 2009 | Mantis 2-Cycle Tiller
Mantis tiller dosnt run right
The carburetor needs to be removed, soaked in a cleaner fluid for a couple of hours, reattached and then adjusted.
May 02, 2009 | Mantis Tiller
Mantis tiller 2 cycle seemed as if it was running out of gas
Check fuel filter and lines, if thay are good I would get a carb kit and set the adjustment screws at 1 turn out from lightley seated to start. Don't lean high speed screw too much.
You might check muffler & cylinder port for carbon first.
Mar 20, 2009 | Mantis 2-Cycle Tiller
Mantis Tiller Logo
893 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
