Question about Kenmore 24032\24036 Top Load Washer
I replace the coppler and a switch,having problems putting the outer skin on the frame kenmore waqsher model # 11021882001
Top washer inside of machine is not working with cycle as it wash
Posted on Mar 09, 2009
But is the side impact beam welded to the outer skin on the right front door of a 2006 buick Lucerne?
dunno about a Lucerne but every car i've worked on;no, the side intrusion beam is spot welded to the inner door frame not to the outer skin & you can drill out the spot welds to remove said beam,although it's a bit of a job!
Sep 13, 2016 | 2006 Buick Lucerne
How to take the outer door skin off
If you take off the outer door skin you will have to replace it. They are folded the welded around the inner frame. Generally a door skin removal tool is used to cut/grind the skin off. There are several youtube videos on this process as it is difficult to explain step by step.
Jul 31, 2016 | Pontiac Fiero Cars & Trucks
The outer skin on the freezer door is scratched. Is there an inexpensive fix to replace the outer skin on model 10651123210
If the scratch is on the smaller side and not a deep gouge, you should be able to obtain touch-up paint for the appliance. These products are usually available at Sears appliance parts depots or more generically at home improvement stores.
Jul 16, 2015 | Kenmore Refrigerators
How do we fix spin problem for our kenmore stackup washer
spining problems notmally are caused because the clutch, the coppler motor or the timer. The timer is the more expensive one. Does spin slow enough for you to stop it wuith your hands? If it does then is not the timer.
May 27, 2012 | Kenmore Washing Machines
My kenmore washing machine model # 11021882001 will fill up with water and drain like it should but does not aggitate at all but it sounds like the motor is spinning freely
Should be one of 2 problems
1 Try and turn the agitator back and forth it should only move in one direction if you can move it both ways then the agitator cam and dogs are worn/broken You can order the kit from HERE
to replace it See this diagram
2 if the agitator is ok then its the drive coupler on the motor You can order it from HERE
Here's how to replace it
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Washing Machines
Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
Sep 16, 2009 | Kenmore 80412 Microwave Oven
How do I replace the lid switch on a Kenmore Model 110.82681110, bought in 1987?
If you allready have the new switch, you are ready to start. If you do not have the part, it is available at www.sears.com under the parts direct tab. you'll need your model number to search out you machine and then the switch.
I find it easiest to remove the entire main case to make this repair. Case removal is as follows:
Disconnect the power cord. 1. There are two screws, one at each front corner, holding the control panel in place, remove them. 2. Remove the two screws at the top, on the back of the control panel. Carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the front of the clips, at the back corners on the top and push back to release them, once again take note to their positioning. 5. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Replace the switch and reassemble reversing procedure. Good luck. Need help? I'm here. Just enter a comment and Fixya will send an email to me.
Aug 01, 2009 | Kenmore 24032\24036 Top Load Washer
REPLACE OUTER SKIN ON FREEZER DOOR
you can get a piece of metal and have it fastioned onto the freezer door with some adheasive like liquid nails. have them take and deburr the metal piece first for you.
Jan 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
REPALCE OUTER SKIN ON FREEZER DOOR
yes the door skin is avaliable here is the part #2222016W your looking at 200 - 250 dollars for this part.
Lid switch for Kenmore washing machine
The real trick to replacing the lid switch is accessing it. This involves removing the outer casing of the washer. The following link will explain how to do this:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any problems along the way, please let me know. I hope this helps you.
PS Make sure you have the washer casing correctly aligned on the frame or the retaining clips will not insert properly. Good luck to you.
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
37 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
