Question about Jabra BT125 Headset
Okay, so I satarted using my Jabra BT125 about 2 weeks ago, It worked fine, until i connected it to my computer. It still works fine with my phone, but when connected to my computer the sound cuts out every half a second. Then comes back one and cuts out again over and over? Do I need new sound drivers or what?
5 Suggested Answers
SOURCE: Jabra connection
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Posted on Feb 13, 2008
SOURCE: My Jabra BT160 won't connect to my Nokia 6103 why?
Try what Shelley says above...hold down the button while you search on your phone. It was the only thing I could get to work with my Jabra and Nokia phone.
Posted on Jul 02, 2008
SOURCE: How to use Jabra BT5010 with 2 mobile phones
how to activate bluetooth jabra
Posted on Jul 05, 2008
SOURCE: Need PIN code to re-connect Jabra BT350 Bluetooth Headset w/phone
I had the same problem-- i asked a verizon wireless guy and he said it's almost always four or six zero's so "0000" or "000000". Hope it works for you!
Posted on Apr 28, 2009
SOURCE: vista cant install jabra bt8030
I just got the same headset and they don't ship with a driver CD.
Try using Bluesoleil for bluetooth connectivity on your laptop. You can get it from
http://www.bluesoleil.com/
Bluesoleil comes with its own drivers for a wide variety of bluetooth functions so you don't have to hunt for specific drivers.
Please note that your bluetooth hardware has to be compatible with bluesoleil. There is is utility on their website that lets you test the same.
Hope this helps.
If this helps, can you have a look into my problem and see if you can help?
http://www.fixya.com/ThreadView.aspx?prdid=919866&thid=2267585
Thanks!
Posted on May 23, 2009
I have a jabra 125 A and I misplaced my instructions it worked fine with my streamer until yesterday and I can't see to get it to pair back up both have full charges.....Hassan
Hassan,
Start with the Jabra is turned off. Then hold down the button for couple of seconds until you see the light flashing.
While the light is flashing, try searching the headset using your phone and use 1234 or 0000 for the Bluetooth pin code.
Hope this helps and good luck!
Jan 02, 2010 | Jabra BT125 Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
How to disconnect bluetooth headset from a lost phone
I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
Jun 04, 2009 | Jabra BT125 Headset
Bluetooth stopped connecting - solid light
I followed one of the solutions that I found on your website! I deleted and added the connection on my phone again and used 0000 as the pin number.
Worked great!
Apr 09, 2009 | British Telecom Jabra BT2010 Wireless...
It's connected fine, now it won't connect, what's up? Jabra BT350
Delete the problem unit off the phone's list then turn the phone off then back on. Next you will have to go through the pairing procedure for the headset again.
Mar 24, 2009 | Jabra BT350 Bluetooth Headset Headset
Will not turn on or charge
get warranty on that one.
Jun 23, 2008 | Jabra BT125 Headset
Connects but won't pair
to connection to your phone or device
turn off your jabra then press and hold the big white button until the light stay on the search for your device
Dec 25, 2007 | Jabra BT125 Headset
Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Nov 30, 2007 | Jabra BT350 Bluetooth Headset Headset
hold the on/off button and the + button for 2 min. If you fail at the first time. Try again, until you see the blue solid light. Search again in your phone, you should see Jabra bt160. Enter 0000 at the passcode. Good luck
Nov 07, 2007 | Jabra BT160 Wireless Headset
Chocolate phone will not discover the Jabra BT150
Oct 07, 2007 | Jabra BT150 Wireless Headset
Jabra BT125 Headset Logo
109 people viewed this question
Top Jabra Radio Communications Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
vimal
vimal
Ed Nelson
Ed Nelson
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
