Washer won't drain or spin
It went through the wash cycle then just sat there full of water
  • pbartlett3 Mar 08, 2009
    My washer ran through the wash cycle, drained, for the most part, but would NOT spin... Any suggestions?
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
Kenmore elite washer won't drain
What is the model number of your washer? This condition is caused by a bad lid switch.
Aug 13, 2012 | Kenmore Washing Machines
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer went through cycle but washer was still full of water and laundry. Did not appear to have spun either. Turned the timer to spin and the timer made noise but did not spin or drain. Water has since...
sounds like the pump is goosed.....or may be just blocked............a penny is the ideal size to block a pump and stop it working...........let me know the outcome....
cheers
Mar 22, 2011 | Washing Machines
Matyag Atlantis washer didn't drain
it could be a bad timer on the machine which tells it to change cycles i had the same problem and had to call them to come fix it. if this part is bad then it will go through asll cycles and never change cycles does that make sense?
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
