Question about Canon PIXMA iP4200 InkJet Photo Printer
Ip4200 error code 5100
My ip4200 won't print and displays error code 5100. Can someone please help?
    President:
  • 2,692 Answers
Answer below taken from another web site:
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Wayne Lischynski - Ebytes Computers
wayne@ebytesonline.com
Posted on Mar 08, 2009
There's an error 5100 appear on my printer canon mp770. I need some help,please.
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Oct 19, 2012 | Canon LASER SHOT LBP-2900 Printer
Error code 5100 (canon ip4200) how do i solve that problem
Aug 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Foutmelding 5100 canon ip4200
error [5100] = CARRIAGE ERROR
you may need to replace
- CARRIAGE UNIT
- TIMING **** STRIP FILM
- LOGIC BOARD ASSY
- CARRIAGE MOTOR
Dec 21, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) sometimes is not lubricated well enough from the factory.
Mar 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have got error code 5100
5100 error code means there is somekind of obstruction inside the printer thats interfering with the printing process. You have to check the inside the printer especially near the gears and under the rollers. The obstruction can be anything like a small piece of paper, a paper clip, ball pin etc., check thoroughly and you will find it. Post back if you need more help.
Dec 03, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Error Code 5100
Carriage error. Paper or the print mechanism is blocked.
It could mean the rollers don't grip the paper, there is torn paper keeping the rollers from turning, the paper can't stick to the rollers etc.,
http://noel.bouvet.free.fr/ip4200/Canon%2520Servicemanual_ip4200.pdf
Sep 01, 2008 | Canon PIXMA MX700 All-In-One InkJet...
I get ERROR 5100 message for my i350 printer...of course it will not print. How is this fixed? Please help.
I had the error code 5100 for my canon pixma ip6220d printer and all it was a pen in the track of the cartridges. I've been looking for that pen for awhile too. So I would say look for something in the way of the cartridges. Hope this helps everyone.
Aug 03, 2008 | Office Equipment & Supplies
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
258 people viewed this question
old marine
old marine
