Question about Hitachi Heating & Cooling
Light not coming on after power outage
The power just went out at my house and before the power went out there were two lights on my air con when it was turned on.Now the power has come back on only one light is on. when the air con is turned off one of the lights is always on but now that is the light not coming on.
    Problem Solver:
  • 8 Answers
Try resetting the circuit breaker.
Posted on Mar 10, 2009
Power light blinking And no cold air coming out
most units have a diagnostic plate on door or manual that will tell you what blinks mean. steady blink is normal on some units.
Jan 20, 2014 | Heating & Cooling
No power at all after an power outage
Before you investigate the TV and its power supply, have you confirmed that the outlet is still delivering the voltage? Sorry if I ask but you said you turned everything back on after the power failure and I didn't know if you meant equipment in the house or all circuit breakers in the house.
Dec 31, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
Power steering failure v air con use
This is because the belt may be worn out or may not be tighten properly. The belt may be lose so that the AC stole all the power from the car. There is a little chance that the compressor may be in problem.If you don't have any idea about the compressor make it off.If you found familiar just adjust it to tighten the belt.
The power steering may fail due to the following reasons:
http://www.carproblemzoo.com/car/lose-power-steering-problems.php
Jun 15, 2013 | Cars & Trucks
I have an LG LCD 55LH40 tv where the screen went black. My directv was doing some kind of reboot because we had a power outage, bad weather, and it restarted and the tv was on and the screen said the
Good day..
that problem is cause of bad inverter board or T-con board..
If you have backlight the problem is T-con board..if no back light the problem is inverter board..
Hope it helps..
Jun 13, 2012 | LG 55LH40 55 in. LCD HDTV
My tv clicks to come on but no sound no picture
If there was a power outage the problem is likely in the power supply.
The power light on the front comes on or not?
If no power light unplug the set and follow power cord inside and check the fuses---the click is a power relay activating---set may have up to 3 black relays on the power board.
Let me know your skill level and I will be happy to help.
SD TECH
Jan 16, 2012 | Hitachi 57F500 57" Rear Projection...
Had a short power outage now the unit will not run. breaker ok and 234 volts to outside unit but inside unit will not come on. is there a reset or something
Try turning the unit off at thye meter box or the isolator switch out next to the outdoor unit of the air con. Leave off for 15 minutes and then switch back on again. Some Air cons get screwed up with power surges... Leaving off at the mains for a while often resets them. If the air con was running at the time the power went off, it may have damaged one of the electronic boards... Do you get any flashing lights or displays showing what could be an error code ??
Jul 16, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Rca d52w20
if you had a power surge from the outage it could be anything. disconnect from the house power and try again in an hour.
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
How to reset my Jenn-Air Jxt8836ADS kitchen hood?
According to Jenn-Air (Maytag) if you remove the power from the hood for 15 minutes it will reset the board. So depending on how long the power was out the outage would have done this. There is a good possibility that the outage ruined your board.
Oct 31, 2007 | Jenn-Air JXT8836ADS Kitchen Hood
Heating & Cooling Logo
183 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
