Question about JVC AV-32050 32" TV
The tv skeen stays black but the red light stays on . is my tube blowned out and needs replaced .idon't know can you tell me ?
If the screen is black but on, as opposed to black because it is off, check to see if your timer is set to turn the tv off.
Posted on Mar 08, 2009
LG PLASMA TV
U have no audio and no video which tells you that it has to be something that both systems have in common - the power supply.
Locate the PS board and check for blown fuse, burnt resistors, bad or bulging caps.
Jul 24, 2015 | LG Televison & Video
When i turn my tv on the screen just stays black. You can hear the volume. I just replaced my bulb about a month ago. I took the bulb out again to see if it was blown and it wasnt. Does anyone know wh
send me a email slinteriors@yahoo.com and I will send you the info to retreve the error code to find out why the set is shutting down. Be sure to include the moodle number and symptoms with your email
Feb 10, 2013 | Mitsubishi WD-65C9 65" DLP HDTV
Hello, I have an RCA standard definition television. Whenever I press the power button, instead of turning on the red power LED flashes (about 24 times) and then stays lit. There is no picture or sound,...
The High voltage Horizontal output transistor is dead.That the transistor sit outside of the wall of the FBT-flyback tranformer is a black block of plastic with a red wire with a cap hook to a CRT-(tv tube) U have soldering iron,a roll of solders and know basic electronic.The "H" trasistor replaced that and resolders the FBT-flyback transformer,should solved this problems.
Jan 29, 2011 | RCA TruFlat 27F520T 27" TV
Sony KV-32FX68U problem, blinking power light
Please update this with the count of hte blinks. This is a diagnostic code that will indicate the problem circuit. From that we can tell you probable solutions and their costs.
Thanks,
Dan
Sep 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How does tv know when lamp is expired -changed bulb after yellow lighht came on but light stayed on months later the light went to red and tv wont turn on
When the lamp goes on a DLP you get no picture, if the light came on and you still had a pic then it might have been telling you ,you had other problems. If the TV wont come on now check your bulb it might be blown this time. The bulb will have lots of small peices of glass in it when its blown. They should last a few years each (3-4).
Jul 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a Hitachi Model # 53SBX59B. After the TV is on for a half hour to an hour, the picture starts turning red and then it goes black with no picture. I was told there are three tubes in it and one...
Does it go to a bright red screen with arched lines going through it and then go black? or does it fade to black? You could have a problem with the red tube but this is no small feat to change. you would need to know the service codes for the convergence menu to align the new tube after changing it. Let me know what its doing and ill be able to help further.
Thanks
Tim
Sep 11, 2008 | Televison & Video
Blown tube?
tube replaement in these units are extremely labor intensive. shadow may mean a bad focus pack or it could mean a bad tube or bad crt board. but i would suggest geting a tech to look at it
Mar 12, 2008 | RCA D61W20 61" Rear Projection Television
JVC AV-32050 32" TV Logo
102 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
