Question about Maytag SDG3606A Gas Dryer
Dryer does not heat the starter will start the flame but it got disconnecter after couple of second...No matter what program is choosen
  • 6,784 Answers
Check the following to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jun 03, 2009
Working on a Kenmore 110.79902890 gas dryer. Unit has intermittent heating. Setting doesn't matter. I have metered the fuse, flame sens., hi limit therm., and replaced the coils on gas valve ... Everything...
I know of a place that offers <a href="http://www.quality-appliance.com/Services/">dryer repair in Nampa, ID</a>. I would try contacting them. I'm sure they could help you out.
Oct 05, 2013 | Dryers
Kenmore Elite HE3 not heating up when vent connected
check outside of house for any obstructions to the outlet. make sure the vent is clean
Jan 02, 2013 | Dryers
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
I have a gas dryer not heating properly. it heats up for about 15 seconds then stops heating for about 15 seconds and continues doing the same. i ohmed out my cutoffs and stats and fuse. all good. im...
Does the actual flame come on or just the igniter? if flame comes on I would start be disconnecting the vent from the dryer and then running dryer. If still the same problem you can rule out a vent restrictiion problem. If its just the igniter coming on with no flame then check your burner coils on the gas valve. They should check less than a couple K ohms. A bad coil will read infinite ohms.
Sep 22, 2011 | KitchenAid Dryers
My dryer does not have heat.
If the heating element has a flame starter, turn off the gas for five minutes and re-light the flame. If it's a piazo starter, you need a new one.
Jim Hart
Jun 14, 2010 | Maytag Neptune MDG9700A Gas Dryer
Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Sep 03, 2009 | Dryers
I have a AMANA gas dryer model LGA80AW and it is not heating. I took the front panel off cleaned the lint from within the cabinet and exhaust pipe. What I've noticed is that the starter comes on and lights...
When you say "starter" I assume you are talking about the "ignitor" and it is glowing.If the ignitor stays glowing continuously then the radiant heat sensor, normally closed, is not opening OR if the ignitor lights up than turns off after about 10 seconds but no flame, then the coils (doesn't matter which one of the two) are bad. The coils are located on top of the gas valve and the radiant sensor is located on the side of the burner chute....Good Luck
The Squirrel
Mar 26, 2009 | Amana Dryers
Kenmore dryer
ok im still with you ,,,,now what i need you to do is start dryer and listen to the gas vavle ,,it will click once than a couple of seconds it will click again,,than you should hear the gas light,,now your at left corner listing,,if you have no clothe in dryer the flame should stay on about 3-5 mintues..after the dryer heats up and shuts of it should come back on in about the same time 3-5 mintues,,listen for rattling or not clicking open the second time around,,if this is the case replace dryer vavle coils,,keep me posted,,onthejob..if the ignitor sensor were bad it would not light at all.they rearly go bad...
Jan 10, 2009 | Kenmore 63942 Dryer
Kenmore 70 gas dryer will heat for 7 minutes then nothing
Change these:3d37aa7.jpgthey get hot and quit, then cool off and work some more.
Dec 31, 2008 | Kenmore 73952 Gas Dryer
Maytag SDG3606A Gas Dryer Logo
269 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
