Question about Motorola Mobility RAZR V3
RAZR V3xx won't recognize micro SD card
2GB Card was working fine until I tried to use an 8GB card, now it won't recognize the original 2GB card. (No, the 8GB doesn't work either).
What's your problem?lg900g won't recognize micro sd
The LG900g works with microSD cards. Your 8GB card is actually a microSDHC card. While microSDHC cards will fit into the slot, they are electronically compatble and will not work in devices not specifically designed to work with the higher-capacity cards. You need to use microSD cards, 2GB and smaller.
Oct 14, 2012 | SanDisk Electronics - Others
Hello, I have bought an adapter micro sd xd adapter for an old finepix f10 photo camera. I have tried more micro sd card 2GB, 4GB, 8GB with this new adapter, but is is not working in my finepix f10. It...
Your Finepix F10 does not support SDHC (High Capacity) memory cards.
You can only use standard SD cards with a maximum capacity of 2GB.
New technics are not always backwards compatible, sorry for that.
Jul 21, 2011 | Cameras
My Sandisk micro card works fine in my phone, but my computer nor my photo printer will recognize it when it is in the adapter that came with it. Is there something that has to be done with the adapter or...
Hello, it depends how old your equipment is as SD cards and SDHC are not necessarily compatible, so if your pc and printer were designed in pre-SDHC days, then you probably wont get any success trying to reading your card.
SD cards only support 2gb max, and in order to support larger capacity for the same style card, the mapping of SDHC cards is totally different, so SD-supported equipment can't 'understand' the new mapping circuitry.
There's some interesting reading in Wikipedia which might clarify things better than my explanation.
Of course, this might not be the solution, but it's worth trying out an SD card if you have one, but I've noticed that SDHC cards are being advertised as SD cards; the only clue that they're actually SDHC is in the capacity, ie, >2gb.
Regards,
nicam49
Jan 28, 2011 | SanDisk 8GB microSDHC Memory Card with...
Tried to download software for r4 micro sd card 4gb sh but does'nt work.comes on the ds loading ,works fine with 2gb sd card,any ideas? thank's colin
Hey there Colin,
The original R4 card only works with Micro-SD cards up to 2GB in size. To use Micro-SD cards up to 32GB, you need to buy the newer R4 SDHC card or a Nintendo DSi comaptible card. Check out R4 Cards / R4 DS Cards from DSCardWorld.com or NDS-Gear.com (NDS-Gear is probably better if you live in Europe or Canada as their shipping's slightly better internationally).
Oct 14, 2009 | SanDisk 2GB microSD Memory Card
MMy motorola razr phone deosn't recognize 4 gb PNY
The 4gb card may be larger than the maximum card size that the phone can read. The maximum may be 1 or 2gb. If its over the maximum size supported the phone wont be able to recognise it
Sep 22, 2009 | Motorola Mobility RAZR V3
Micro sd card
yes 4GB is the maximun motorola specifiy using on the v3xx
Jun 23, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Installing a 2GB PNY Micro SD Card
Only the Sprint version of this phone supports memory cards over 1 Gigabyte. Sorry. But if you have a Sprint phone comment back to me using the comment box below. Thanks.
If you don't have a Sprint phone you need to acquire a 1GB card and use that. Hold on to your 2GB card as it will be usable when you upgrade at the end of your contract period.
Regards,
Worldvet
Jun 11, 2008 | Motorola Mobility RAZR V3
Micro card
When I bought the phone I wanted to use a bigger Memory card. I was told it will only recognize 2gb. The booklet that comes with phone says the same thing, so would assume that is why it says full. Assuming of course youre trying to use more than 2gb at the moment.
Jun 05, 2008 | LG KU990 Viewty
Motorola V3xx I-mode
Under the settings for usb connection type change the setting to memory card connection. This is subject to having a memory card (Micro sd) installed. Otherwise you may have to install motorola phone software into your computer and use this to update files on your phone.
Regards,
David M-G
Feb 20, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Large sd micro cards than originally intended?
soda monster, first of all wuz up man? the answer is yes, i had a razor v3i pretty much same thing to urs, and i installed a 2gb micro sd and it worked, and later i replaced it with a 4 gb card and it worked too. but sometimes when u have to many songs and pictures the phone will become slow and at times freezes ur phone too much, u will have to remove the battery and turn it back on, thats the only bad part , so a 2gb micro sd is recommended.
Feb 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3 Logo
309 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
