Question about ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
ESA 42 in, has sound, screen has colored lines going thru.
The lines are yellow, red and sometime the screen is just all blue. The TV was working just fine until it was turned off and turned back on. No I have sound but not picture at all.
  • CGARB May 04, 2009
    ME TOO...HELP
  • 23 Answers
What type of t.v is it.
Let me know, and i can help but to me it sounds like a busted Processor, but dont listen to me untill i know what your viewing candy is
LCD, PLASMA, OLED, DLP, LP, CRT what type of t.v do you have?
Posted on May 02, 2009
My LG 42 Plasma works sometimes then half the screen goes black but the right side stays perfect???
have almost the same problem left side is black with sometime blue line red lines or a whole bunch of different lines some one help please have sound and right side of tv works fine
Sep 26, 2010 | LG 42PC3D 42 in. Plasma Television
I have a tv that only shows variations of blue and yellow no matter what i do to the menu color options. However the menu will show all of the colors but not the normal screen.
it sounds like an rgb problem it depends what your playing thru your tv but if its coming thru a component lead eg red green and blue it sounds like your missing the red feature also it could be a pin bent on your scart which is carring the red portion of the picture , What kind of set is it and what are you playing thru it ?
Mar 02, 2010 | Akai LCT2060 Television
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Mar 23, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
ESA plasma TV model pdp 4294lv1 does not work
my esa plasma tv model pdp 4294lv1 has sound and i can switch the tv channels, but the color is blurrier
Jul 22, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
Esa plasma tv
I knead the wire for the spikers I losted and is imposibe to get sound on my TV plasma esa 42"
Aug 29, 2007 | NEC - 42" Commercial Plasma Screen ****(no...
ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV Logo
357 people viewed this question
Top ESA Televison & Video Experts
Demonic-2011
Demonic-2011
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
