Question about Lenovo IdeaPad Y510 Notebook
Replace keyboard on Y510
I need to get directions and or photos on how to replace the keyboard on Lenovo Ideapad Y510
  • makala001 Mar 08, 2009
    This is an Ideapad notebook, not a Thinkpad. I couldn't find any screws on the bottom with any symbols by them. Thank you for your efforts. It is appreciated.
    I didn't underlined "notebook" on first comment.
    I found the solution!! The piece above the keyboard (has lines on it) must be removed. There is a slot between F2 and F3 that you can slip a straight blade into, then twist slightly, this will start to loosen the cover. Just keep twisting along the edge until it pops loose. Then, just gently lift up the keyboard from the top, stand up and gently push the bottom forward (there are little hooks on the bottom. Lift up and remove. Gently remove the ribbon cable. Reverse procedure to install new keyboard. Thanks for your help.
OK, Here is the official Lenovo Service Manual for every component on the Y510.
http://consumerdl.lenovo.com.cn/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/Y450/Lenovo%20IdeaPad%20Y450%20Hardware%20Maintenance%20Manual%20v2.0.pdf
However, removing the panel above the keyboard is not as simple as just removing the 4 screws located in the battery compartment and the three along the back edge on the bottom. Yes there are some "L" brackets on either end that are a pain to get to let go, but I found that by removing the DVD drive and removing the screw in the bay edge closest to the top panel, it helped loosen things to remove the top bezel. You may have to use a small flat blade screwdriver to pry the front edge up by the PF keys. Be careful removing the top bezel though, there are two small electrical ribbons attached to it for the volume and other controls. Once you have the top bezel ose, you simply have to lift the top edge of the keyboard and release the connector ribbon by flipping up the front edge of the connector. the manual illustrates this. Then it's just a matter of reversing the order. Reassembly is must easier and faster than disassembley.
Posted on Aug 27, 2010
  • Jadineva Nov 03, 2010
    This manual you linked to is for the Y450, not the Y510...is the instruction the same?
  • joecoolvette
    joecoolvette May 06, 2012
    NO, the LCD Front Bezel does not come off that way.
  • Lenovo Master
  • 32,281 Answers
The keyboards on ThinkPads are easy to replace.
On the bottom of the laptop there are screws that hold the keyboard in place (possibly 3 or 4 screws). These screws can be identified by the tiny keyboard symbol next to these screws. Remove these screws, you need a small Phillips screw driver. You can now lift the keyboard off, you may need a small flat screw driver to lift it off. The keyboard is attached to the motherboard by one or two ribbon cables, they are held in place by slide catches, slide these catched to release the tension on the ribbon cable/s so you can withdraw the ribbon cable/s.
When you insert the new keyboard make sure the cable catches are in the released position before you insert the ribbon cable, insert the cable fully home and press the slide catches home to lock the ribbon cable to the motherboard.
At this stage I suggest you power up the laptop and test the keyboard to see if it is functioning correctly. If is not working properly, then the ribbon cable/s may need reseating again. When all is OK now fix the keyboard in place with the screws.
Posted on Mar 08, 2009
  • Chris Hingee
    Chris Hingee Mar 08, 2009
    I saw Lenevo heading and assumed it was a ThinkPad model, anyway I have worked on a lot of laptops and they most of them fix the keyboard the same way as the ThinkPad,
    You will notice the keyboard screws are located under the keyboard and not in the corners of the laptop. Remove these screws and gently lift the keyboard free, if it won't budge then look for other possible screws on the bottom of the laptop at the LHS and RHS of the keyboard. The ribbon cable attachment can be plug connection (easier to remove and attach) or ribbon cable attachment as previously described.
    If in doubt, remove all the screws, take a note of where the various screws are located as they can vary in length. There maybe other screws under the battery, CD/DVD drive and hard drive compartments.
    The top and bottom of the laptop case are held together with plastic clips and therefore the case will not fall apart on you.
More on "Replace keyboard on Y510"
Here's another point: When you start to lift the keyboard up from the back, there are three little plastic "L" clips on both the feft and right sides of the laptop's top case enclosure that are used to keep the left and right sides of the keyboard down in place. So what you need to do to keep from damaging those little "L" clips is to gently bend the keyboard in the middle a little while you are lifting the keyboard up. That will make the overall width of the keyboard shorter and it should more easily clear those little "L" clips.
Don't forget what was previously said about getting the bottom on the keyboard out. You need to get the keyboard up in the air to about 90 degrees or a little less, then shove down a little to get the "L" hooks (on the keyboard this time) to clear the case (ie. the bottom of keyboard comes out moving towards the back of the laptop.
Posted on Jul 24, 2009
Is it possible to replace Ideapad Y510 motherboard
review the cases lenovo , what has velocity and performance vs y510, directly with Lenovo factory or some store
Sep 18, 2013 | Lenovo Computers & Internet
Stk770d
Please refer to this link to find the exact file you are looking for:
http://consumersupport.lenovo.com/ot/en/driversdownloads/drivers_list.aspx?categoryid=43
Jul 01, 2012 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
I am looking for lenovo ideapad y510 LCD screen replacement guide. My Screen is cracked
Hi 284607,
I see you need assistance on replacing the LCD screen on your Lenovo Y510 Laptop.
I have a link here that you can got do and download the information on how to replace the LCD screen on your Lenovo Y510 machine but then again just a disclaimer, any damages that may occur during the replacement Lenovo will not be held Liable.
See link for the Details:
LCD replacement Y510
I hope that this helps.
Have a nice day,
mvincentc
May 26, 2011 | Lenovo IdeaPad Y510 Notebook
I have the keyboard for my Lenovo Y510, how do I install it?
basically, there is a pre-installed driver for keyboard in Y510. Check the keyboard if it work. If it is not, then turn off the pc, remove cables and battery.
Press and hold the power button for 5 seconds, reinsert the battery and keyboard then turn on the pc.
Then check if the keyboard works...
Dec 13, 2009 | Lenovo IdeaPad Y510 Notebook
Neither of the shift work correctly therefore
Your keyboard is shorted. Your computer needs a new keyboard.
Oct 05, 2009 | Lenovo IdeaPad Y510 Notebook
Where is the cpu located in the Lenovo Ideapad Y510
hi,
I Lenovo Notebooks cpu is located at the extreme left upper corner and when you will open then the heatsink will be visible on it.
after opening the screw of the heatsink simply turn the non removable screw and then lift the cpu.
Dec 26, 2008 | Lenovo IdeaPad Y510 Notebook
Where is the cpu located in the Lenovo Ideapad Y510?
here is the user manual which includes photos etc
http://dl.okglb.com/consumerdl.lenovo.com.cn/UserFiles/UserGuide/en/User's%20guides%20and%20manuals/Y510/Y510%20User's%20Guide.pdf
you will need adobe and want to read pages 12 and 13 in adobe (actual manual pages are pages 7and8)
as far as i can tell you do not have to access this from under the keyboard, you only need to remove the bottom larger center panel.
<a href="http://s66.photobucket.com/albums/h258/am8r0s1a/myspace/?action=view&current=manual.jpg" target="_blank"><img src="http://i66.photobucket.com/albums/h258/am8r0s1a/myspace/manual.jpg" border="0" alt="Photobucket"></a>
Dec 26, 2008 | IBM ThinkPad T20 2647 Notebook
Lenovo Y510 keyboard not responding
first try to search a new material with configuration panel ,if you don't find anything replace it at your resseller
Dec 15, 2008 | Lenovo IdeaPad Y510 Notebook
Lenovo IdeaPad Y510 Notebook Logo
4,138 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
