Question about Motorola Televison & Video
Motorola DVR player: ''Standby'' mode necessary to record?
Does my Motorola DCH3416 DVR player have to at least be in ''Standby'' mode in order for it to record my scheduled shows? I'd like to take it off standby - power down - to save on energy but don't want it to miss any of my scheduled recordings.
3 Suggested Answers
  • 374 Answers
SOURCE: DVR won't set a timer to record a show
I have never encountered this but if you have enabled the standby and it still does not work you will need a new receiver. The feature was to enable a screen saver so that televisions screens would not be etched if it were left on and you fell asleep. My suspicion is that the DVR hard drive is corrupt giving you this false message.
Thanks for using Fix Ya.
Posted on Apr 28, 2009
  • 155 Answers
SOURCE: i received an error 4 code on my comcast supplied
Hi chestmcn. Here's how you reset your device to its defaults:
1. Make sure your receiver is plugged in, that it's connected to your TV, and that your TV is turned on.
2. Turn your receiver OFF, then press MENU on the front panel of the box. You will then see a menu on your TV.
3. Using either the up/down buttons on your remote control or the up/down buttons on the front of your receiver to navigate. Use the right arrow button to view the options for each setting.
4. Arrow down to the setting labeled "Restore All Defaults", then press the right arrow button to select that option.
5. Exit the menu and save your changes by pressing the POWER or MENU button.
For what it's worth, this issue may also be related to Comcast reference code error s0900, which means a disruption in service, usually temporary.
In case you run into more trouble with your receiver, here is a link to the user guide- http://www.motorola.com/staticfiles/Business/Products/TV%20Video%20Distribution/Set-tops/QAM%20Set-tops/All%20Digital%20QAM%20Set-tops/DCH3416/_Documents/Static%20Files/DCH3416_User_Guide_537529-001-c.pdf
I hope this helps. Thanks for using FixYa!
Posted on Jul 07, 2010
Looking for ir extender / blaster to put motorola dch3416 into closet.
Probably best to go to Best Buy or Fry's or some other electronics solutions store where they can recommend a solution. You may find audio visual online communities discussing this.
Mark
Motorola Support
Apr 13, 2014 | Motorola Mobility DCH3416 (160 GB) DTV...
Connect headphones to dvr model 3416
you would need a "doggle" to switch from stereo (the red and white near the yellow on the back) to headphone. i have seen the sort of thing at best buy and radio shack.
good luck
Aug 31, 2011 | Motorola Mobility DCH3416 (160 GB) DTV...
Would like to know how to download prog recorded on DCH3416 onto a usb hard disk connected to my computer for storage
can't... FCC says your not aloud because you may break copyright laws.
that usb port on the dvr only has power... no data. you can use it to charge your phone or power a little fan... thats about it.
sorry
Feb 09, 2011 | Motorola Televison & Video
My box randomly turns off and flashes 8888.
same problem here. stb turns off randomly and displays 8888 and locks itself. usually if your press the select button 4 times and turn the stb on again it works but you will have to wait 20 min for it to get the channels or dvr. still no permanent solution though
Aug 30, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
S0900?
Poor signal. Check connections at all Coaxial connectors. Should be tightened. Unplug a/c from rear of DVR for 30 seconds. Allow time for DVR to reboot and update. Try again. If not resolved, call tech support for your cable company. May have to boost your signal.
Jul 29, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
Can i connect my motorola dch3416 dvr to my laptop and save programs that i recorded to my hard drive?
Motorola DCH3416 has an USB port to connect to a PC. But you can't copy the files from DVR to laptop, they are encrypted and locked down, even if you opened the box and pulled out the drive you wouldn't be able to get a PC to recognize the format or copy the files off the drive.
(You can not connect data devices without contacting your service provider.
Because the Digital Rights Management (DRM) laws instituted by the entertainment industry prohibit the movement of copyrighted content from one system to another.)
Hope this helps
May 31, 2010 | Motorola Computers & Internet
I received an error 4 code on my comcast supplied motorola dch3416 hd dvr, looking up this error on the web it was suggested that i reset the device, but did not specify how. can you help?
Mar 24, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
I want to hook up an external hard drive to increase the record time available for my Motorola DCH3416 cable box. I already have drives with eSata, USB, and firwire ports.
From the Motorola FAQs:
How do I transfer my programs from my Motorola DVR to an external device like a computer or hard drive? trnsp.gif Question How do I transfer my programs from my Motorola DVR to an external device like my computer or hard drive?
trnsp.gif Answer No. Currently you can't offload recorded content to any external device from a Motorola DVR, even though the data ports are there, the software doesn't support it yet. When the option becomes available through a software upgrade, it will be downloaded to DVR automatically by service providers/cable companies.
Jul 09, 2009 | Televison & Video
How to connect a motorola DCH3416 to a computer Can I connect an external Hard drive to a DCH3416 USB or SATA port so that programs record to the externl HDD, or how can I tranfer recorded program to the...
Nope...
The eSATA ports are not configured in the device's firmware, and the USB 2.0 ports are useless except for charging your iPod or powering a USB fan. If you could connect an external drive to the unit, it would be partitioned with data encryption that can only be accessed by the particular DVR that formatted the drive. You can however stream local channels to a video capture card via the firewire ports but cable channels and DVR recorded programs would be encrypted. You can thank the MPAA for the grief...
Jun 24, 2008 | Televison & Video
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Televison & Video Logo
579 people viewed this question
Top Motorola Televison & Video Experts
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
