Question about Mtd Garden
18 5 hp 42 deck mtd shift on the go Drive quit working
I can see smoke coming from underneath. I just replaced the blades and belt. This was given to me and I don't have any manuals for it. I'm not sure how the drive works. I had a Snapper riding mower many years ago and it had a plate on the bottom of the engine and the drive ran off of it. (Not sure how to describe it.)
2 Suggested Answers
  • 133 Answers
SOURCE: middle blade in 3 blade mower for ride on does not seem to cut?
Raise the deck and reach into the bad blade and try and turn it. If it turns easily then try to wiggle the blade up and down. If it moves up and down then the bearings are bad. You will have to remove the shaft and install new bearings. It is best to take it to a shop that can replace them. If you try and beat them off with a hammer you will probably mess up the shaft. I know from experience. You might be able to buy the whole new shaft with bearings already installed pretty cheap. Just find your part number and go to www.jackssmallengines.com and input the part number into the search box. They have reasonable shipping prices. You can also go to your local small engine repair shop they might even have free shipping.
Good luck and let me know if this helps.
thanks
roundo4
Posted on Sep 06, 2009
Testimonial: "Thank you that gives me a good idea where to start."
I have a 17.5 HP Yard Machines,8 speed shift on the go, 42'deck. Worked fine last year, The year, blades would not turn, engine pulley burned up the belt. Replaced the belt, did not solve the problem.
take the belt off and be sure the pulleys turn freely. sounds like you mowed through water and they may have some rust on them or the bearings in the spindles are bad. just take the belt off, turn the pulleys and find the one that is bad and repair it.
May 21, 2017 | Mtd Garden
Craftsman mower deck belt tensioner keeps bouncing and shaking the deck
Bad pulley ???? Bent blade shaft,Bad bearing???
May 31, 2014 | Mtd Garden
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
I have a MTD lawn mower is believe is 21hp with a 42 inch cutting deck, its been chewing up deck belts, i just recently had it gone thru and had the tech replace the deck brakes one was severely worn and...
sounds like one or more of the pulley bearings is frozen or turning very hard just jack up the mower and check each pulley how easy it turns replace bad one hope this helps
Apr 18, 2017 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
Loud noise when clutch is disengaged
Something is locked up underneath, something is preventing your belt from spinning. I recommend going under and inspecting the blade area and also belt area especially if the deck is full of debris. You might even have a frozen bearing or something like that anyhow you need to do a little investigation, pronto buddy. Good Luck
Jul 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
Middle blade in 3 blade mower for ride on does not seem to cut?
thanks
roundo4
Sep 06, 2009 | Mtd Garden
Huskee 42 inch drive belt
does anybody know what kind of drive belt a huskee 24 horse 42 deck takes?
Aug 15, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
167 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
