Question about Whirlpool Duet GHW9150P Front Load Washer
We are experiencing this irritating F 11 CODE problem. With no warranty left,it is very depressing to know what we have to do in order to fix our very expensive WHIRLPOOL washer. Tried calling whirpool but same run around answers as all these other customers. I cant believe WHIRLPOOL dont give a "rats ***" on the F 11 situation. Very dissappointed custumer from Hawaii. Shame on Whirlpool.
    President:
  • 1,294 Answers
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU) (its the
usual thing)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component
Companies want you to dump your machine & go for a new one, keeps their factories running.
Posted on Mar 08, 2009
I have a pain when I push on it just under my left rib cage what could it be also i have been constipated for a while I'm really worried
Here are just a few of the possible reasons you may be feeling pain under the left rib cage:
Gluing gas in the colon - There is a possibility that you have gas trapped in the colon. The amount of gas that has become stuck may be excessive. You can usually feel the pain resonating from the upper left side of the abdomen to the left side of the rib cage.
Irritation in the spleen - There is a possibility that your spleen has already been broken due to several reasons and this can cause some pain in the left rib cage. In order to know if the type of pain you are experiencing is also due to this, you may also want to see if you are experiencing other symptoms such as pain in your left shoulder limbs.
Broken Rib - This is probably one of the most common reasons why you are experiencing pain under the left rib cage. There is a possibility that you feel pain under the left rib cage, because it has broken the rib. Ask yourself if you have been in any accident lately or if you have hit yourself unexpectedly. This may just be one of the reasons you've broken your ribs.
Aug 12, 2017 | Health & Beauty
How do I fix that irritating squeaking noise?
More than likely an idler pulley assembly issue. Best bet is to order a replacement. You might as well replace the drum belt too since it means a complete disassembly of the unit for proper access, cleaning and repair. If you don't have the know-how it's best left to an experienced technician.
Jun 29, 2014 | Frigidaire Dryers
Maytag Neptune FAV6800AWW different clutches?
Call a local parts supply house for example Appliance parts Company 480-755-0005
Jul 15, 2017 | Maytag Neptune FAV6800AW Top Load Washer
Cook top beeping and dislpays E 11
This just happened to me a couple of minutes ago. Nothing would turn it off--even when we flipped the breaker switch, when it came back on, the beeping continued! While I was doing an internet search on it, my husband fixed it--apparently a bit of food directly on a button and the system interpreted that to be someone continually pushing the button. He wiped the control panel and it stopped.
Note to Electrolux: Please don't pretend that error codes don't exist! Rather, put a key to what each code means in the user's guide that comes with the range! This is the second time we've had a code error and it's extremely irritating to not be able to find out what the issue is quickly. It's costing you (Electrolux) money because I WILL call a service tech to come out here. I'm still under warranty so there's no cost to me. I advise you to change your user's guide and also have a key to the error codes that is easily found on your website.
Note to everyone else: If you're under warranty, let Electrolux deal with this. It's only when they realize they're paying more money for trivial service calls than for fixing the problem in the first place that they'll change it!
Dec 12, 2010 | Electrolux EW30ES65GS 30" Slide-in...
HELP... CODES FOR 1996 DODGE GRAND CARAVAN SE. CODES 12, 22, 11, 44, 55. WHAT DO THES MEAN AND HOW TO FIX IT.
11- no start since battery disconnected.
12- battery has been disconnected recently.
22-Coolant temperature sensor, bad connection or faulty.
44-signal to smec (engine computer) was interrupted, or is not present.
55- is end of codes.
What exactly are you experiencing as far as starting and driving goes.
The only code I see right now that I would worry about is the coolant temperature sensor, if you are experiencing poor running, starting etc.
The signal to smec, may have been a one time thing, if vehicle runs.
Feb 02, 2010 | 1996 Dodge Grand Caravan
I WANT TO KNOW WARRANTY DETAILS?
http://www-947.ibm.com/systems/support/machine_warranties/warranties_licenses_maintenance.html
go the above link for warranty and services details
Apr 02, 2009 | Lenovo IdeaPad Y510-1 Notebook
C2 Centurion - won't light
I guess from the manaufacturer or retailers point of view, fixing it yourself would void the warranty as there isn't much you can do without dismantling it more than is necessary to fit batteries.
Apr 12, 2017 | Surefire Camping, Backpacking & Hiking
How to change the Margins
Yurn on, carrige return to left margin. To move to the left, depress the MR or margin release key, back space to where you want margin. There usually a key that says code or mode, up on the top cover if it has not been cleaned off the 3 key is the margin left key and the 4 key is the margin right key. depress the code key and 3 key will set the left margin. Hope this helps...
Jun 10, 2008 | Brother GX-6750 Typewriter
Zanussi JetSystem TurboDry JD12191 - HELP!!
Just 11 month! Do not try to fix it, jet. You have 10 days warranty left. I hope you have your buy ticket/invoice/recipe call service center as soon as possible! In case your warranty expired, there are many probable causes of the failure. You need to give a more detailed description of the problem. It is probable that you can find the user manual in the manufacturers webpage. Or google "your model"+manual Good Luck!
Aug 27, 2007 | Washing Machines
Mouse Problem
What you are experiencing is normal wear and tear of the mouse button that is used the most. This is a common issue with mice made for computer manufacturers. Most likely issue is that after 2 years of clicking, the depress switch was actually pushed into the plastic molding below. A new mouse would really be the most effective use of time and resources. I would recommend a high quality mouse from logitech (a g5 or g7) would significantly increase hand comfort, response and posture. Their warranty period is also top notch. Hope this helps.
Aug 01, 2007 | Compaq HP 2Button Optical Carbon USB Mouse
Whirlpool Duet GHW9150P Front Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
