Question about Kwikset 907 907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt
Have to enter code in several times to unlock because deadbolt won't unlock all the way when entered the first time.
    President:
  • 2,692 Answers
Dissassemble  clean and lub lock.
Posted on Mar 08, 2009
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Kwikset smartcode deadbolt newly installed unlocks when lock button pushed. I have taken batteries out and reset few times with no success.
"I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?"
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
These instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
These locks are made to work on a door which, when you stand outside and face it, has its hinges on either the left-hand or right-hand side of the door (= door "handedness").
The jumper controls that for the appropriate installation. Yours is set wrong!
Jul 10, 2012 | Kwikset 907 907-11P Venetian Bronze Smart...
Door will unlock without entering code
"Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial? "
Feb 15, 2012 | Schlage BE365-PLY BE365PLY626 Satin...
Just installed keyless entry lock. Lock button works fine, enter code and deadbolt only partially retracts. Worked fine the first time, will not completely unlock since. Key works to fully unlock. Tried...
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish.
Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Good luck-and please provide feedback if this helps!
Oct 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I held the black button down untill it beeped and then reset the entry codes (they were compromised). Since then it beeps after an unlock code is entered, then it beeps a few times and will not respond to...
ok -- so you know about the black re-set button ( that saves me some time ),,
1. push and hold the black button untill it beeps 3 times -
2. enter your new code,, 4 to 8 digits and then press the 'LOCK' button.
it should now be programmed to your new code.
now if you want to add more codes to the lock -- just push the black button twice and enter next code and hit the ' LOCK ' button,,, this will store the next code.
make sure you test the lock several times so you do not get locked out.
also -- change your battery once or twice a year ( depending on use ) to be sure it never dies.
now the reason it does not respond to button function is because it goes into lock down mode after about 3 tries,, this is a security function of the lock,,, before you try the re-program - let the lock sit idle for 5 minutes or so,, also just to make sure the lock does not get over excited - remove the battery and let sit for a few more minutes,, ( this is just a extra step that I do out in the field whenever I encounter this problem ) --- and yes I am a locksmith.
best of luck to you,, if you have anymore troubles - please write me back here and I will do my best to walk you through it.
have a great night,
c...
Feb 05, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
My Powerbolt 1000 only works with the key in the deadbolt lock. I have a code entered that unlocks the deadbolt only with the key in the deadbolt. Your help is appreciated.
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
Good luck--and please provide feedback if this helps!
Oct 17, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Won't unlock door and beeps when code is entered
Got in contact with kwikset took out battery pack then put it back in. keypad reset itself.
Dec 28, 2008 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Kwikset 907  907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt Logo
268 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Iron
Iron
Ted Rishel
Level 1 Expert
Richard Roth
Richard Roth
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
